Old 07-11-2011, 07:17   #1 (permalink)
cellcare prasad's Avatar
Member: 602547
Sonork: 100.1621466
Thanks Meter: 930
c1-00 rm689 dead after flash,(SOLVED)
Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921600
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rm689_003.000
Downloading item CODE:hw_s01_rm689_r03.000.fls, num block: 3, size: 4.11 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 59.453 s
Erasing area 0x00C60000-0x00E6A87E ...OK
Programming completed in 57.672 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.203 s
Checksum verified (0x446F)
Processing file: rm689_003.00ij
Downloading item CUST:hw_s01_rm689_003.00ij.fls, num block: 1, size: 1.88 MB
Erasing area 0x00210000-0x003EF7FE ...OK
Programming completed in 53.453 s
Checksum verified (0x6BD4)
Processing file: rm6890_nai03.00ij
Downloading item CUST:hw_s01_rm6890_nai03.00ij.fls, num block: 1, size: 327.45 KB
Erasing area 0x00EB0000-0x00F010BE ...OK
Programming completed in 9.125 s
Checksum verified (0xD7EA)
Total time for flashing process(boot+erase+write) was 4 min 33.546 s
Old 07-11-2011, 07:29   #2 (permalink)
HBHAVNA's Avatar
Member: 1418631
Sonork: 100.1622972
Thanks Meter: 79
C1-00 dead after flash
Originally Posted by prasadak2811 View Post
module ver: 1.0.0.17743(23-06-2011), library ver: 1.0.0.11773(23-06-2011)
do not disconnect or abort this operation otherwise phone will be damaged.
Cpu: Xgold 110
sending ebl loader ...ok
sending ebl ...ok
getting ebl version ...
Boot mode: 0xcc
ebl version major/minor: 10.19
ebl version : Default_ram_bootloader
set baud rate to: 921600
flash id: 0020 88c0 [st m58mwr064fu,64 mbits]
processing file: Rm689_003.000
downloading item code:hw_s01_rm689_r03.000.fls, num block: 3, size: 4.11 mb
erasing area 0x00800000-0x00a0fffe ...ok
programming completed in 59.453 s
erasing area 0x00c60000-0x00e6a87e ...ok
programming completed in 57.672 s
erasing area 0x00ffc000-0x00ffc03e ...ok
programming completed in 0.203 s
checksum verified (0x446f)
processing file: Rm689_003.00ij
downloading item cust:hw_s01_rm689_003.00ij.fls, num block: 1, size: 1.88 mb
erasing area 0x00210000-0x003ef7fe ...ok
programming completed in 53.453 s
checksum verified (0x6bd4)
processing file: Rm6890_nai03.00ij
downloading item cust:hw_s01_rm6890_nai03.00ij.fls, num block: 1, size: 327.45 kb
erasing area 0x00eb0000-0x00f010be ...ok
programming completed in 9.125 s
checksum verified (0xd7ea)
total time for flashing process(boot+erase+write) was 4 min 33.546 s
bro dont use 3.00 use 2.5 or 2.6 version of falsh file to falsh nokia c1-00 because u use 3.00 the main falsh file mcu checksum verified error! Certificate mismatch. Used 2.6 set will be ok 10000000000000000000000000%
The Following 2 Users Say Thank You to HBHAVNA For This Useful Post:
Old 07-11-2011, 13:54   #3 (permalink)
Member: 602547
Sonork: 100.1621466
Thanks Meter: 930
thanks my friend my problem solve, thanks alot
Old 12-06-2012, 11:00   #4 (permalink)
Hussain_Mobile's Avatar
Member: 681758
Sonork: 100.1676160
Thanks Meter: 347
thanks my problem also slove thanks
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2000 22:24
Page generated in 0.13281 seconds with 9 queries
