05-14-2011, 10:38 | #1 (permalink) |
Registered User Join Date: Apr 2007 Location: Ludhiana PUNJAB India Age: 37
Member: 492884 Status: Offline Thanks Meter: 143 | c1-01 not flash with mx-key just show this (ANSWERED) Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 35EECF96 WriteDevice failed: A device attached to the system is not functioning |
05-15-2011, 13:05 | #3 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
i have the same problem with c1-01, i dont use any hub and i can flash most type using usb before, like: x2-00, x2-01, c3-00, etc. only this type c1-01 i have problem.. what do u mean by diasble any program that utilize usb prot (ovi, etc) maybe u should explain in our language (indonesian), thanks in advance bro... br | |
05-15-2011, 14:12 | #4 (permalink) |
Banned Join Date: Dec 2010 Location: Islamic repablic of pak Age: 37
Member: 1468508 Status: Offline Sonork: 100.1584728 Thanks Meter: 159 | MXKEY Serial: [USB Smart Card Reader 0] - C08 Driver: nmwcdc, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Battery voltage: 3984 mV Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: F0F12C Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 2.3 EBL version : Quantum_Bootloader_2.3_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6500000 Flash ID: 0089 8982 [Intel NU48F512,512 Mbits] Processing file: rm607__04.40.mcusw Downloading item CODE:rm607__04.40.mcusw_ebl_psi.fls, num block: 5, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.344 s Erasing area 0x40040000-0x4007FFFE ...OK Programming completed in 0.485 s Erasing area 0x40080000-0x4009FFFE ...OK Programming completed in 0.343 s Erasing area 0x400A0000-0x4019FFFE ...OK Programming completed in 1.344 s Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 27.391 s Checksum verified (0xD471) Processing file: rm607__04.40.ppm_m_c Downloading item CUSTackage_m_c.ppm_ebl_psi.fls, num block: 1, size: 3.11 MB Erasing area 0x41C00000-0x41F1A50A ...OK Programming completed in 3.640 s Checksum verified (0x4A12) Processing file: rm607__04.40.image_m_c_0596379 Downloading item CUSTackage_m_c_0596379.image.fls, num block: 1, size: 11.38 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming completed in 13.344 s Checksum verified (0x363C) Total time for flashing process(boot+erase+write) was 6 min 40.235 s Waiting for device boot up ... Device found: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 18BD9CDE Verifying communication to device OK. Phone Type: RM-607 (C1-01) SW Version: V 04.40 23-02-11 RM-607 (c) Nokia Imei plain: 3559620 Product Code: Battery voltage: 3965 mV, current: 139 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! Imei net: 35596 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.922 s Nokia C1-01 USB Phonet detached. |
05-16-2011, 20:31 | #5 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
if you don't understand clearly, please write on gsmindonesia. I'll help you on own language. BR | |
10-05-2011, 15:45 | #6 (permalink) |
Junior Member Join Date: Aug 2003
Member: 36600 Status: Offline Thanks Meter: 2 | i hve the same erroe encountered today. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 35EECF96 WriteDevice failed: A device attached to the system is not functioning i detached all USB hubs/ device aside from the mxkey disabled all usb softwre |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
