03-29-2012, 08:06 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: FENI,BANGLADESH Age: 38
Member: 537829 Status: Offline Thanks Meter: 96 | c1-01 usb flashing show eror....... (ANSWERED). Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000C540 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.73 Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 9EF9DDC then nothing happen............ |
03-29-2012, 08:16 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. select & tick DCT4 XGOLD, if you are working with BB5. the main problem of yours is that you are using old version will not working, use latest mxkey update will solve your problem. have a nice day. br, zuberchowdhry |
04-01-2012, 06:10 | #6 (permalink) |
Member: 537829 Status: Offline Thanks Meter: 96 | i have tried with defferent file but same stop flash on ppm 99% here is log:- Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Sections : 05 Current File : rm607__06.05.mcusw Compile Name: rm607__06.05.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26217904 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 05 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 9899 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 05 FIRMWARE Erase Block: 0x40040000~0x4007FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 262144 bytes Data Checksum: 0000 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 05 FIRMWARE Erase Block: 0x40080000~0x4009FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 865C Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 of 05 FIRMWARE Erase Block: 0x400A0000~0x4019FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 9347 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 of 05 FIRMWARE Erase Block: 0x40400000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24641536 bytes Data Checksum: 89AE Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm607__06.05.ppm_v Compile Name: package_v.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4266532 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x41C00000~0x421FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4263188 bytes Data Checksum: 7993 Uploading Data Blocks to phone... 99% HANG ON THIS STEP. |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Need solution for 3210 v5.01 | tati | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-20-2000 21:55 |
