05-08-2011, 13:38 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | C1-02 RM-643 NOT ABLE TO FLASH WITH MX-KEY 3.4 ver 2.1 (ANSWERED) Code: MXKEY Serial: [FT SCR2000 0] - C08005EB Driver: nmwcdnsuc, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 280ADC75 Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0x 0 EBL version major/minor: 0.0 EBL version : Protocol version suggested by phone: 0 WriteDevice failed: The specified procedure could not be found Set baud rate to: 6500000 WriteDevice failed: A device attached to the system is not functioning WriteDevice failed: A device attached to the system is not functioning WriteDevice failed: A device attached to the system is not functioning could not read flash id ! THE PHONE IS ASKING FOR SECURITY CODE WBR sahil2000ind |
05-08-2011, 14:36 | #5 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Added, XGOLD213 devices(RM-607,RM-608,RM-643,RM-644 etc) usb flashing support (dead/alive) [WF] THIS WAS ADDED IN 3.4 ver 1.8 ANY HELP FROM SUPPORT TEAM. WBR sahil2000ind |
05-09-2011, 08:23 | #7 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | ALREADY CHECKED WITH OTHER SYSTEM BUT SAME PROBLEM. I THINK ITS NOT SUPPORTED WITH MX-KEY AS I NOT SEE ANY SUCCESS STORIES OF C1-02 RM-643 WITH MX-KEY. ANY MORE SUGGESTION FROM THE SUPPORT TEAM? WBR sahil2000ind |
05-09-2011, 11:12 | #8 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | STILL SAME WITH THE NEW 3.4 VER 3.1 Code: MXKEY Serial: [FT SCR2000 0] - C08005EB Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16818(08-05-2011), Library ver: 1.0.0.9921(04-05-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 280ADC75 Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0x 0 EBL version major/minor: 0.0 EBL version : Protocol version suggested by phone: 0 WriteDevice failed: The specified procedure could not be found Set baud rate to: 6500000 WriteDevice failed: A device attached to the system is not functioning WriteDevice failed: A device attached to the system is not functioning WriteDevice failed: A device attached to the system is not functioning could not read flash id ! PLS HELP ME WITH THIS PROBLEM WBR sahil2000ind |
05-09-2011, 12:25 | #9 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | PROBLEM SOLVED FLASHING DONE WITH Phoenix_Service_Software_2011.08.005.45529_Cracked Code: Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Download files list initiated Waiting for USB device... Booting... Sending EBL loader... Sending EBL... Boot successful Downloading file: rm643__04.40.mcusw Erasing 131070 bytes... Total progress: 6% Sending data... Total progress: 12% Erasing 262142 bytes... Total progress: 15% Total progress: 18% Sending data... Total progress: 24% Erasing 131070 bytes... Total progress: 30% Sending data... Total progress: 36% Erasing 1048574 bytes... Total progress: 38% Total progress: 40% Total progress: 42% Sending data... Total progress: 48% Erasing 24641534 bytes... Total progress: 50% Total progress: 52% Total progress: 54% Sending data... Total progress: 56% Total progress: 58% Total progress: 60% Downloading file: rm643__04.40.ppm_mh Erasing 3967326 bytes... Total progress: 62% Total progress: 64% Total progress: 66% Total progress: 68% Total progress: 70% Sending data... Total progress: 72% Total progress: 75% Total progress: 77% Total progress: 80% Downloading file: rm643__04.40.image_mh_0597733 Erasing 12713982 bytes... Total progress: 82% Total progress: 84% Total progress: 86% Sending data... Total progress: 88% Total progress: 90% Total progress: 92% Erasing 917502 bytes... Total progress: 94% Total progress: 96% Total progress: 98% Total progress: 100% Resetting device Phone flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Doing factorysets Factorysets complete Loading default data to phone Loading default data to phone Getting Data Package Reading product state Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: DateTimeSettings, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ISSVariantActivator, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 3 items were not backed up Default data loading complete Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. WBR sahil2000ind |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
