11-17-2011, 08:50 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | c1 & c2.....ERROR: Could not verify communication ! (ANSWERED) MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN:shani Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.70 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Battery voltage: 3814 mV Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 13AAA1D1 Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version : Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbps Flash ID: 0089 8982 [Intel NU48F512,512 Mbits] Processing file: rm702__06.51.mcusw Downloading item CODE:rm702__06.51.mcusw_ebl_psi.fls, num block: 4, size: 28 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.391 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.375 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.469 s Erasing area 0x40280000-0x41D3FFFE ...OK Programming completed in 33.344 s Checksum verified (0x2541) Processing file: rm702__06.51.ppm_m_a Downloading item CUSTackage_m_a.ppm_ebl_psi.fls, num block: 1, size: 3.98 MB Erasing area 0x41DC0000-0x421BB1B2 ...OK Programming completed in 5.265 s Checksum verified (0x3098) Processing file: rm702__06.51.image_m_a_059D434 Downloading item CUSTackage_m_a_059D434.image.fls, num block: 1, size: 10.63 MB Erasing area 0x424C0000-0x43E1FFFE ...OK Programming completed in 13.094 s Checksum verified (0x7C42) Total time for flashing process(boot+erase+write) was 6 min 55.828 s Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 13AAA1D1 Verifying communication to device... ERROR: Could not verify communication ! Phone type: RM-702 (C2-03) SW version: V 06.51 15-07-11 RM-702 (c) Nokia Imei plain: 35932504306628-9 Product code: 059D434 Battery voltage: 3789 mV, current: 100 mA Language Pack: - not available. Imei net: 35932504306628 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.031 s Nokia USB Phonet detached. |
11-18-2011, 07:03 | #3 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | sam problam. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN:shani Connection status: UHCI:HUB:USB 1.10 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.72 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 13AAA1D1 Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 2.5 EBL version : Quantum_Bootloader_2.5_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbps Flash ID: 0089 8982 [Intel NU48F512,512 Mbits] Processing file: rm607__05.45.mcusw Downloading item CODE:rm607__05.45.mcusw_ebl_psi.fls, num block: 5, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.375 s Erasing area 0x40040000-0x4007FFFE ...OK Programming completed in 0.781 s Erasing area 0x40080000-0x4009FFFE ...OK Programming completed in 0.375 s Erasing area 0x400A0000-0x4019FFFE ...OK Programming completed in 1.969 s Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 29.687 s Checksum verified (0x4831) Processing file: rm607__05.45.ppm_m_n Downloading item CUSTackage_m_n.ppm_ebl_psi.fls, num block: 1, size: 3.39 MB Erasing area 0x41C00000-0x41F62AF2 ...OK Programming completed in 4.656 s Checksum verified (0xA714) Processing file: rm607__05.45_004.image_m_n_ctv_ng_9h063 Downloading item CUSTackage_m_n_ctv_ng.image.fls, num block: 1, size: 12.13 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming completed in 17.250 s Checksum verified (0x0F4A) Total time for flashing process(boot+erase+write) was 7 min 4.047 s Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 13AAA1D1 Verifying communication to device... ERROR: Could not verify communication ! Phone type: RM-607 (C1-01) SW version: V 05.45 22-06-11 RM-607 (c) Nokia Imei plain: 35698404295368-2 Product code: 0596699 Battery voltage: 3695 mV, current: 113 mA Language Pack: - not available. Imei net: 35698404295368 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
02-06-2014, 17:13 | #6 (permalink) |
Freak Poster Join Date: Oct 2008 Location: At Work always
Member: 885483 Status: Offline Thanks Meter: 15 | need help with this please MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C08129F8 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0000856F Connection status: EHCI:HUB:HUB::USB 1.10 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.84 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-02 USB Phonet, PORT_ID: E9C250F Verifying communication to device... ERROR: Could not verify communication ! Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-02 USB Phonet, PORT_ID: E9C250F Verifying communication to device... ERROR: Could not verify communication ! |
02-07-2014, 16:43 | #7 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. What is Phone condition right now, It's seems like Hardware or Water-logged, Try clean PCB & again Flash it. BR, ZUBER |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Nokia 5110 & 6110 Schemics | MyKy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-06-1999 08:36 |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
