12-07-2011, 16:13 | #4 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 47
Member: 170098 Status: Offline Thanks Meter: 15 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: C0858DB2 Using device: HTI, FW ver: 00.24, SN: 00008E59 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 2EA00005EF005940AF40B7A7B9777E24E4A9355F ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 3.0 size: 0x9AD43 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 Processing MCU file: rm721__11.10.mcusw [BB5,XSR 1.6] size: 28.57 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 37.69 MB CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-0009FFFF] CMT FLASH,MuxOneNAND area [000A0000-0025FFFF] CMT FLASH,MuxOneNAND area [003E0000-005DFFFF] CMT FLASH,MuxOneNAND area [005E0000-010DFFFF] CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF] CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF] CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF] CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 8443ECD5 [] sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 25.219 s Processing PPM file: rm721__11.10.ppm_meac [BB5,XSR 1.6] size: 5.80 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Partitioning ...OK Erase size: 8.87 MB CMT FLASH,MuxOneNAND area [01EE0000-027BFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 17.718 s Processing CNT file: rm721__11.10.image_meac_059G290_005 [BB5,XSR 1.6] size: 16.27 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Partitioning ...OK Erase size: 75.06 MB CMT FLASH,MuxOneNAND area [02CC0000-077BFFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 48.922 s Total time for flashing process(boot+erase+write) was 2 min 41.9 after this fone only show nokia and get off |
12-07-2011, 16:16 | #5 (permalink) |
Member: 170098 Status: Offline Thanks Meter: 15 | and this bus check Using device: HTI, FW ver: 00.24, SN: 00008E59 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 2EA00005EF005940AF40B7A7B9777E24E4A9355F ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 3.0 size: 0x9AD43 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 Original Imei: 35594004572112 Original Product code: 059D676 Bluetooth ID: AC932F87347C SIMLOCK PA identifier: [0] PA_SIMLOC30 |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
Need solution for 3210 v5.01 | tati | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-20-2000 21:55 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
