Member: 64823
Thanks Meter: 439 | c2-01 RM-721 ERROR while flashing (was DEBRANDING)!! Phone NOW DEAD LOG: Quote:
MXKEY [FT SCR2000 0], SN: Cxxxxxx
Using device: USB ROM and HTI, FW ver: 00.50, SN: xxxxx
Connection status: OHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.72
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011)
Processing MCU file: rm721__11.20.mcusw
[BB5,XSR 1.6] size: 28.57 MB
Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: B363997
CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: 2370000705FF5E40E4C941A0988CEBD345BA80A6
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT ROM ID: 67E82268F29CEA60
Loading CMT secondary boot code
SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0
Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 37.69 MB
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-0009FFFF]
CMT FLASH,MuxOneNAND area [000A0000-0025FFFF]
CMT FLASH,MuxOneNAND area [003E0000-005DFFFF]
CMT FLASH,MuxOneNAND area [005E0000-010DFFFF]
CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF]
CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF]
CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF]
CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 8443ECD5 [] sent
CMT RAP3NAND block sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
WriteDevice failed: Overlapped I/O operation is in progress
Error while programming [00] at 0x00820400, Result: 0000
Task failed at (0800001C)!!!
Last RX buffer: 80 10 6F 00
Use other TOOL to revive: Quote: Connect phone on selected interface...
Core version : 1.30 Rev : 1.1
Selected FlashSettings : FullFlash
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm721__11.20.mcusw
PPM : rm721__11.20.ppm_meaa
CNT : rm721__11.20.image_meaa_059G1H6_006
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Connection opened successfully
Waiting for communication response...
[BB5 FLASH]: Bootrom Ok!
CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00001051
EM1 ID: 00001060
ASIC MODE ID: 00
Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 11.34.0
Processing RAWLOADER...
FLIC : 003000EC
Req : XSR 1.6
Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 11.34.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:02
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 8443ECD57D2EDADDAADBAD248F1B3B559E14D184
ADL: phone is in flash mode
===Flashing [MCU]===
Erase : Processing rm721__11.20.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm721__11.20.mcusw
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [MCUSW]
CMT: Writing Hash CERT [MCUSW1]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [ISA+DYNSW]
Total writen 134 blocks
TIME : Write time : 00:00:39
MCU Write done
ADL: Request programm status
NAND status : 00000000 / 00000000 / 00000000
===Flashing [PPM]===
Erase : Processing rm721__11.20.ppm_meaa
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm721__11.20.ppm_meaa
Total writen 24 blocks
TIME : Write time : 00:00:08
PPM Write done
===Flashing [CNT]===
Erase : Processing rm721__11.20.image_meaa_059G1H6_006
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:01
Write : Processing rm721__11.20.image_meaa_059G1H6_006
Total writen 67 blocks
TIME : Write time : 00:00:23
CNT Write done
ADL: Close_Session
Content: 000300000000000000000000000000
ADL: Reboot
Flashing done!
Total flash time : 00:01:13
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia C2-01
Software Info: V 11.20 27-10-11 RM-721 (c) Nokia
IMEI: 358650044279784
PPM version : V 11.20 27-10-11 RM-721 (c) Nokia MEA
Product code: 059G527
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Resetting LifeTimer
Reset Done!
Checking User Certificates...
Total - 34 certs
Data exist, skip certificate repair...
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Elapsed: 00:01:42
Connect phone on selected interface... | |
