Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 04-13-2012, 19:08   #1 (permalink)
leonirvana's Avatar
Member: 290434
Sonork: 100.1606522
Exclamation C2-01 RM-722 ++ contact service ++ (ANSWERED)
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: xxxxx
Using device: USB ROM and HTI, FW ver: 00.50, SN: 00011B31
Connection status: OHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: 2BC00116F8F31049DB2CF75669BEBB8329E7DEE7
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT ROM ID: 67E82268F29CEA60
Loading CMT secondary boot code
SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0
Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 247EE179
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184
Selected firmware certificate matched.
Original Imei: 35792204176319
Original Product code: 059J113
Bluetooth ID: 10F9EE28A207
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for device boot up ...
Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 31E73F1A
Verifying communication to device OK.
Phone type: RM-722 (Nokia C2-01)
SW version: V 11.00 17-03-11 RM-722 (c) Nokia
Imei plain: 35792204176319-8
Battery voltage: 3604 mV, current: 187 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00IIIIRR0301035602, ver: 001.002
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 357922041763198
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 7223400000000000
PROFILE_BITS: 8000000000000000
BLOCK1: 1=CLOSED(MCCMNC), DATA=72234F
Log read by usb . Phone still in contact service.
also flashed , all process ok, but same situation.
anyone can provide me PM ?? other solution ?
Old 04-13-2012, 19:44   #2 (permalink)
ms phone's Avatar
Member: 1119242
[0] PA_SIMLOC30
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
check hardware
clean board mybe water damage
Old 04-13-2012, 20:00   #3 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
bro. do self test & post test logs.
Old 04-13-2012, 20:30   #4 (permalink)
leonirvana's Avatar
Member: 290434
Sonork: 100.1606522
Phone Type: RM-722
ID Test name Startup Result
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y !failed !
46 UEM_CBUS_IF Y passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N passed
43 LCD N passed
21 LPRF_IF N passed
44 LPRF_AUDIO_LINES N passed
2 CURRENT_CONS N passed
42 RADIO Y passed
23 KELVIN_BATVOLTAGE N !no signal
19 KELVIN_VIBRA N passed
26 KELVIN_CAPACITOR N passed
29 KELVIN_MISC N passed
28 KELVIN_MIC N passed
31 KELVIN_CHARGING N passed
27 KELVIN_AUDIO N passed
116 KELVIN_XEAR N passed
105 INTERNAL_ANTENNA N passed
69 BACKLIGHT Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
71 BT_WAKEUP N passed
96 HOOKINT N passed
88 TAHVOINT Y passed
101 BTEMP N passed
8 MBUS_RX_TX_LOOP Y passed
90 PWR_KEY N passed
128 CDSP_SLEEPCLOCK_FREQ N passed
86 CDSP_RF_BB_IF N !no signal
83 CDSP_RF_SUPPLY N !no signal
85 CDSP_TX_IQ N !no signal
74 CDSP_TXC_DATA N !no signal
79 CDSP_RX_PLL_PHASE_LOCK N !no signal
80 CDSP_TX_PLL_PHASE_LOCK N !no signal
75 CDSP_WCDMA_TX_POWER N !no signal
81 CDSP_RX_IQ_LOOP_BACK N !no signal
77 CDSP_GSM_TX_POWER N !no signal
Old 04-14-2012, 07:37   #5 (permalink)
Member: 262425
Sonork: 100.1617691
bro. your problem is here in self test logs: 12 SIM_CLK_LOOP Y !failed !
check or change RETU ic.
Old 04-14-2012, 10:50   #6 (permalink)
specta's Avatar
Member: 1149800
im speechless
good luck bro
br
Old 04-14-2012, 11:03   #7 (permalink)
Member: 262425
Sonork: 100.1617691
Originally Posted by specta View Post
im speechless
good luck bro
br
dear specta, my suggestion for contact service not country lock & he too want to solve that. sim clk loop failed appears for contact service many times solved by replacing RETU ic when buscheck OK.
br,
zuberchowdhry
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 04-14-2012, 15:13   #8 (permalink)
leonirvana's Avatar
Member: 290434
Sonork: 100.1606522
can give me same info about RETU IC ? where is placed in pcb...
Old 04-14-2012, 17:14   #9 (permalink)
Member: 262425
Sonork: 100.1617691
bro. its next to RAP, a big ic name PEARL(NEW RETU) ic, but be careful its may not be available in market, so try to reflow.
Old 04-14-2012, 20:06   #10 (permalink)
gbluez's Avatar
Member: 73565
im speechless
good luck bro
br
Nothing wrong with simlock.
Phone got HW damaged on simlclock. Rooted on power chip.
try to reball first, careful, very thin bga pitch balls.
The Following 3 Users Say Thank You to gbluez For This Useful Post:
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-27-2012 11:00
gsm service provider sidou Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-30-2000 11:09
Need solution for 3210 v5.01 tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 01-20-2000 20:55
FREE SP unlock service timxy Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-22-1999 16:05
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.77816 seconds with 11 queries
