05-29-2012, 16:27 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | c2-02 Contact service Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010XXX5A Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) Battery voltage: 3607 mV Warning battery voltage is less, phone might not detected after flash ! Waiting for USB device removal ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 0126300XXXXX94 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK LOCK120_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_0126300XXXXX94_ back.RPL" Processing file: rm692__06.52.mcusw Downloading item CODE:rm692__06.52.mcusw_ebl_psi.fls, num block: 4, size: 28 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.328 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.344 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.344 s Erasing area 0x40280000-0x41D3FFFE ...OK Programming completed in 31.156 s Checksum verified (0xE21F) Processing file: rm692__06.52.ppm_m Downloading item CUSTackage_m.ppm_ebl_psi.fls, num block: 1, size: 3.74 MB Erasing area 0x41DC0000-0x4217C736 ...OK Programming completed in 4.328 s Checksum verified (0x437B) Processing file: rm693__06.52_001.image_m_vivo_br_9h2z8 Downloading item CUST:/1WORKAREAS40/Project_Snapshot/R , num block: 1, size: 12.38 MB Erasing area 0x424C0000-0x43E1FFFE ...OK Programming completed in 15.437 s Checksum verified (0x66FD) Total time for flashing process(boot+erase+write) was 3 min 26.282 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-02 USB Phonet, PORT_ID: 1735F682 Verifying communication to device OK. Phone type: RM-693 (C2-02) SW version: V 06.52 19-07-11 RM-693 (c) Nokia Imei plain: 0126300XXXXX94-7 Product code: 059H2Z8 Language Pack: - not available. SIMLOCK_DATA corrupted! Phone Type: RM-693 SW version: V 06.52 19-07-11 RM-693 (c) Nokia ID Test name Startup Result 33 SIM_LOCK N !failed ! 93 SECURITY N passed 90 PWR_KEY N passed 2 CURRENT_CONS N passed 12 SIM_CLK_LOOP N passed 43 LCD N passed 44 LPRF_AUDIO_LINES N passed 21 LPRF_IF N passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 71 BT_WAKEUP N passed 96 HOOKINT N passed 101 BTEMP N passed 118 RF_ANTENNA N passed 112 CDSP_PA_TX_POWER N passed 227 SLEEP_CLOCK_FREQ N passed 52 KEYB_LINE N passed 10 ADC_IF N !no signal 50 MEMORY_CARD_IF N passed 60 TOUCH_STUCK N passed 103 TOUCH_IF N passed 17 RF_PLL N passed 45 FEM_CURRENT N !failed ! 47 SECURITY_FUSE N passed |
05-29-2012, 16:32 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. better return it to customer. BR, |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
05-30-2012, 04:24 | #6 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: GSMFORUM Age: 37
Member: 1133716 Status: Offline Thanks Meter: 282 | Quote:
i think you need rpl calculation to solve your problem | |
The Following User Says Thank You to powerlogic For This Useful Post: |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
Nokia 6150 5.02 Stupid Security Code!!! | Ringnet | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-04-2000 01:27 |
gsm service provider | sidou | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-30-2000 11:09 |
FREE SP unlock service | timxy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-1999 16:05 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
