12-12-2011, 06:52 | #4 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Ues: version rev.1.5 1. nokia usb rom as interface 2. turned of phone, mark fast flash, un mark safe flash. 3. load files by market 4. press flash, insert usb cable, press pwr on shortly [email protected] |
12-13-2011, 13:13 | #7 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | c2-03 usb flashing just want to share succesful usb flashing of nokia c2-03 check flashing logs...more power mx-key MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: shani Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdc, ver: 7.1.32.72 Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2327C065 Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version : Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbps Flash ID: 0089 8982 [Intel NU48F512,512 Mbits] Processing file: rm702__06.97.mcusw Downloading item CODE:rm702__06.97.mcusw_ebl_psi.fls, num block: 4, size: 28 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.453 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.438 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.531 s Erasing area 0x40280000-0x41D3FFFE ...OK Programming completed in 31.485 s Checksum verified (0xA701) Processing file: rm702__06.97.ppm_ea Downloading item CUSTackage_ea.ppm_ebl_psi.fls, num block: 1, size: 4.48 MB Erasing area 0x41DC0000-0x4223A286 ...OK Programming completed in 5.750 s Checksum verified (0xD0EE) Processing file: rm702__06.97.image_ea_059D3W3 Downloading item CUSTackage_ea_059D3W3.image.fls, num block: 1, size: 11.13 MB Erasing area 0x424C0000-0x43E1FFFE ...OK Programming completed in 13.469 s Checksum verified (0xEC75) Total time for flashing process(boot+erase+write) was 6 min 43.250 s Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-03 USB Phonet, PORT_ID: 1EC4BDBA Verifying communication to device OK. Phone type: RM-702 (C2-03) SW version: V 06.97 20-09-11 RM-702 (c) Nokia Imei plain: 35XXXXXXX Product code: 05XXXX Battery voltage: 4117 mV, current: 91 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! Imei net: 35XXXXXXXXX Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.203 s Formating FS: FILE2 ... Completed in 0.422 s |
MY-C2! any way to unlock this phone ? | infogsm | ARM9 BASED M62 / M62+ | 27 | 01-08-2004 00:37 |
Sagem MY-C2 Cables and Terminator Dongles >> | mobile-bits | Main Sales Section | 0 | 11-04-2003 01:56 |
Can you remove second c2 on z5 board and without any care more, just remove ? | DREAMGSM | Samsung Hardware Repair | 0 | 05-27-2003 11:20 |
C2.00.20 lp7 needed | Skoku | Motorola Old Legacy (EMMI) | 6 | 08-26-2002 12:49 |
f_loader for 8210 v 5.26 or C2 flash | greenapple | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 07-31-2001 02:25 |
