04-07-2014, 15:04 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Poland
Member: 112498 Status: Offline Thanks Meter: 33 | c2-05 contact service.... After flash with latest firmware is still the same" Code: MXKEY [FT SCR2000 0], SN: C080B930 Using device: USB ROM Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.115 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 337E2F2B Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35835xxxxxxxxx441 RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_3583xxxxxxxxxx2441_back.RPL) Processing file: rm724__08.87.mcusw Downloading item CODE:rm724__08.87.mcusw_ebl_psi.fls, num block: 4, size: 25.50 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.475 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.547 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 2.148 s Erasing area 0x40280000-0x41ABFFFE ...OK Programming completed in 57.473 s Checksum verified (0xB866) Processing file: rm724__08.87.ppm_b Downloading item CUST:package_b.ppm_ebl_psi.fls, num block: 1, size: 4.36 MB Erasing area 0x41B40000-0x41F9B242 ...OK Programming completed in 9.178 s Checksum verified (0x8541) Processing file: rm724__08.87.image_b_dgray_059F9X3 Downloading item CUST:package_b_dgray_059F9X3.image.fl , num block: 1, size: 14.75 MB Erasing area 0x42240000-0x43E1FFFE ...OK Programming completed in 25.039 s Checksum verified (0x9C2D) Total time for flashing process(boot+erase+write) was 5 min 25.157 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-05 USB Phonet, PORT_ID: 358xxxxxxxxx924411 Verifying communication to device OK. Phone type: RM-724 (C2-05) SW version: V 08.87 17-10-12 RM-724 (c) Nokia Imei plain: 358xxxxxxxxxx441-1 Product code: 059G0M8 Language Pack: - not available. SIMLOCK_DATA corrupted! I also have got 2 pieces of working c2-05. Can I write PM from one of those to my dead Nokia? Emilkawa |
04-16-2014, 15:10 | #3 (permalink) | |
Member: 112498 Status: Offline Thanks Meter: 33 | Quote:
I can put it there: Pliki u?ytkownika emilkawa - Chomikuj.pl If you can't find I bcan send you by email. Regards, Emilkawa | |
04-23-2014, 08:35 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Please can you put your Backup RPL like you uploaded your PM, Here is your saved RPL: C:\mobileEx\3.5\data\backup\XGOLD_3583xxxxxxxxxx24 41_back.RPL BR, ZUBER |
04-23-2014, 14:12 | #5 (permalink) | |
04-24-2014, 09:49 | #7 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. I don't think this modified my edited PM will help, But just extract this .rar file & try to write this PM, Your Simlock section in your original backup PM is already damaged, so may be this will not help, BTW write my PM & post result. BR, ZUBER |
05-05-2014, 12:05 | #8 (permalink) | |
Code: MXKEY [FT SCR2000 0], SN: C080B930 Using device: USB ROM Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.115 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 337E2F2B Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 337E2F2B Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35835005092441 RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35835005092441_back.RPL) Processing file: rm724__08.87.mcusw Downloading item CODE:rm724__08.87.mcusw_ebl_psi.fls, num block: 4, size: 25.50 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.955 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.452 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.800 s Erasing area 0x40280000-0x41ABFFFE ...OK Programming completed in 45.077 s Checksum verified (0xB866) Processing file: rm724__08.87.ppm_b Downloading item CUST:package_b.ppm_ebl_psi.fls, num block: 1, size: 4.36 MB Erasing area 0x41B40000-0x41F9B242 ...OK Programming completed in 11.031 s Checksum verified (0x8541) Processing file: rm724__08.87.image_b_dgray_059F9X3 Downloading item CUST:package_b_dgray_059F9X3.image.fl , num block: 1, size: 14.75 MB Erasing area 0x42240000-0x43E1FFFE ...OK Programming completed in 42.306 s Checksum verified (0x9C2D) Total time for flashing process(boot+erase+write) was 5 min 26.822 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-05 USB Phonet, PORT_ID: 358350050924411 Verifying communication to device OK. Phone type: RM-724 (C2-05) SW version: V 08.87 17-10-12 RM-724 (c) Nokia Imei plain: 35835005092441-1 Product code: 059G0M8 Language Pack: - not available. SIMLOCK_DATA corrupted! Writing PM from Node ... Section: 3 - Key: 0, size 2 bytes written. Section: 4 - Key: 1, size 800 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 78 bytes written. - Key: 19, size 4 bytes written. - Key: 26, size 132 bytes written. - Key: 28, size 2 bytes written. Section: 8 - Key: 0, size 2 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 16 bytes written. - Key: 3, size 128 bytes written. - Key: 4, size 128 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 8 bytes written. - Key: 10, size 32 bytes written. - Key: 11, size 4 bytes written. - Key: 12, size 4 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 241 bytes written. Section: 13 - Key: 0, size 1 byte written. - Key: 1, size 2 bytes written. - Key: 2, size 1 byte written. - Key: 3, size 2 bytes written. - Key: 4, size 1 byte written. - Key: 5, size 1 byte written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 2 bytes written. - Key: 9, size 1 byte written. - Key: 10, size 1 byte written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 1 byte written. - Key: 14, size 1 byte written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 1 byte written. - Key: 18, size 1 byte written. - Key: 19, size 8 bytes written. - Key: 20, size 1 byte written. - Key: 21, size 1 byte written. - Key: 22, size 1 byte written. - Key: 23, size 1 byte written. - Key: 24, size 1 byte written. - Key: 25, size 2 bytes written. - Key: 26, size 1 byte written. - Key: 27, size 1 byte written. - Key: 28, size 1 byte written. - Key: 29, size 1 byte written. - Key: 30, size 1 byte written. - Key: 31, size 1 byte written. - Key: 32, size 1 byte written. - Key: 33, size 1 byte written. - Key: 34, size 1 byte written. - Key: 35, size 1 byte written. - Key: 36, size 1 byte written. - Key: 37, size 4 bytes written. - Key: 38, size 1 byte written. - Key: 39, size 1 byte written. - Key: 40, size 1 byte written. - Key: 41, size 1 byte written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 1 byte written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 1 byte written. - Key: 48, size 4 bytes written. - Key: 49, size 1 byte written. - Key: 50, size 1 byte written. - Key: 51, size 1 byte written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 1 byte written. - Key: 56, size 1 byte written. - Key: 57, size 1 byte written. - Key: 58, size 2 bytes written. - Key: 59, size 1 byte written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 1 byte written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 1 byte written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1 byte written. - Key: 69, size 1 byte written. - Key: 70, size 1 byte written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 1 byte written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 1 byte written. - Key: 79, size 1 byte written. - Key: 80, size 1 byte written. - Key: 81, size 1 byte written. - Key: 82, size 1 byte written. - Key: 83, size 2 bytes written. - Key: 84, size 1 byte written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 1 byte written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 1 byte written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 1 byte written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 1 byte written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 byte written. - Key: 116, size 1 byte written. - Key: 117, size 1 byte written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 1 byte written. - Key: 121, size 1 byte written. - Key: 122, size 1 byte written. - Key: 123, size 8 bytes written. - Key: 124, size 1 byte written. - Key: 125, size 1 byte written. - Key: 126, size 1 byte written. - Key: 127, size 1 byte written. - Key: 128, size 1 byte written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 131, size 1 byte written. - Key: 132, size 1 byte written. - Key: 133, size 2 bytes written. - Key: 134, size 1 byte written. - Key: 135, size 2 bytes written. - Key: 136, size 1 byte written. - Key: 137, size 1 byte written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 140, size 1 byte written. - Key: 141, size 1 byte written. - Key: 142, size 1 byte written. - Key: 143, size 1 byte written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 148, size 1 byte written. - Key: 149, size 1 byte written. - Key: 150, size 1 byte written. - Key: 151, size 1 byte written. - Key: 152, size 1 byte written. - Key: 153, size 1 byte written. - Key: 154, size 1 byte written. - Key: 155, size 1 byte written. - Key: 156, size 1 byte written. - Key: 157, size 1 byte written. - Key: 158, size 1 byte written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. - Key: 161, size 1 byte written. - Key: 162, size 1 byte written. - Key: 163, size 1 byte written. - Key: 164, size 1 byte written. - Key: 165, size 1 byte written. - Key: 166, size 1 byte written. Section: 24 - Key: 0, size 1 byte written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. - Key: 23, size 40 bytes written. - Key: 24, size 40 bytes written. - Key: 25, size 40 bytes written. - Key: 26, size 40 bytes written. Section: 49 - Key: 1, size 4 bytes written. - Key: 2, size 1 byte written. Section: 54 - Key: 0, size 2 bytes written. Section: 96 - Key: 0, size 2 bytes written. - Key: 1, size 20 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 136 bytes written. - Key: 26, size 12 bytes written. Section: 111 - Key: 1, size 4 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Section: 117 - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 16, size 62 bytes written. Section: 120 - Key: 0, size 78 bytes written. - Key: 1, size 160 bytes written. - Key: 2, size 130 bytes written. - Key: 3, size 112 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 163 - Key: 0, size 8 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 202 - Key: 0, size 1 byte written. Section: 217 - Key: 0, size 32 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 238 - Key: 1, size 1 byte written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Section: 308 - Key: 0, size 1 byte written. - Key: 3, size 1 byte written. - Key: 4, size 1 byte written. - Key: 5, size 10 bytes written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 1 byte written. - Key: 9, size 40 bytes written. Section: 322 - Key: 0, size 1 byte written. Section: 339 - Key: 0, size 511 bytes written. - Key: 1, size 511 bytes written. Section: 341 - Key: 0, size 1 byte written. - Key: 3, size 4 bytes written. Warning: failed to write 341 - 4 (4518 bytes) Section: 354 - Key: 0, size 15 bytes written. Section: 355 Warning: failed to write 355 - 0 (12068 bytes) Completed in 7.425 s What can I do else? Emilkawa | |
