08-31-2011, 05:36 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Daet Cam., Norte Philippines
Member: 824202 Status: Offline Sonork: zyx_lexus Thanks Meter: 5 | C3-00 restart problem! (ANSWERED) I tried to read it via bus check. Everything is fine! I tried to use BB5 SW Downgrade fix. But I got phone not responding error! when I try to check via bus check again now appears NPC data invalid Waiting for device boot up ... Phone not found, retrying ... Device found: nmwcdc\Nokia C3-00 USB Phonet, PORT_ID: 1FCB7364 Verifying communication to device OK. Phone Type: RM-614 (C3-00) SW Version: V 04.60 31-08-10 RM-614 (c) Nokia Imei plain: 12345610654321-? Product Code: 059C4Q3 Battery voltage: 3939 mV, current: 1 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Invalid Certificate Data, backup will not be created. Error saving backup ! how can I fix this? I got a npc rpl ang back rpl back up please give me procedure! TIA! |
08-31-2011, 19:37 | #2 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Makum, Assam, India
Member: 1540165 Status: Offline Sonork: 100.1606502 Thanks Meter: 29 | Try with latest firmware and post result. Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Invalid Certificate Data, backup will not be created. Error saving backup ! Think rpl is solution |
The Following User Says Thank You to KKBaruah For This Useful Post: |
09-03-2011, 04:42 | #4 (permalink) |
Member: 824202 Status: Offline Sonork: zyx_lexus Thanks Meter: 5 | I've already flashed it now with the latest firmware but still the same. IMEI corrupted. 12345610654321? appears. I try again to use rebuiled and restore IMEI but still same done with errors appear. This all started when I use the BB5 SW Downgrade fix... Any solution? |
09-03-2011, 04:48 | #5 (permalink) |
Member: 824202 Status: Offline Sonork: zyx_lexus Thanks Meter: 5 | heres the logs after flashing with latest firmware: Device found: nmwcdc\Nokia C3-00 USB Phonet, PORT_ID: 1FCB7364 Verifying communication to device OK. Phone Type: RM-614 (C3-00) SW Version: V 08.63 25-03-11 RM-614 (c) Nokia Imei plain: 12345610654321-? Product Code: 059C4Q3 Battery voltage: 3925 mV, current: 1 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Invalid Certificate Data, backup will not be created. Error saving backup ! |
09-03-2011, 07:49 | #6 (permalink) | |
No Life Poster Join Date: May 2008 Location: Bangladesh
Member: 782943 Status: Offline Sonork: 100.1601067 Thanks Meter: 204 | Quote:
Br. Rasel | |
09-03-2011, 08:48 | #7 (permalink) |
Member: 824202 Status: Offline Sonork: zyx_lexus Thanks Meter: 5 | yes I tried restore IMEI but still no luck here is the logs: RPL: "C:\mobileEx\3.4\data\backup\RPL\35484404678***_NP C.rpl" Imei: 35484404678*** Access violation at address 03E8BCE6. Read of address 00000000 Operation done with error. Is there any solution? TIA! |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
