Old 03-06-2012, 14:14   #1 (permalink)
dilshad_noori's Avatar
Member: 1293519
Sonork: 100.1596500
Thanks Meter: 169
Arrow c3-00 rm614 flash don by mxkey
MXKEY [Generic CCID Smart Card Reader 0], SN: C0000000
Using device: USB ROM
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.73
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
Processing MCU file: rm614__08.70.mcusw
[BB5,XSR 1.6] size: 27.92 MB
Supported Ids: 2200050920030000, 22000509200C0000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 36D9154B
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 00000000001173A1F668D38816EB807AB32981C5
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH:
1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x178 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35431804315481_CE RT.rpl"
CMT PAPUBKEYS HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 33.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT ADA block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 697F7477 [RAP Certificate v1 232] sent
CMT UPDAPP block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 14.540 s
Processing PPM file: rm614__08.70.ppm_a1
[BB5,XSR 1.6] size: 6.17 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
Programming completed in 3.247 s
Processing CNT file: rm614__08.70_009.image_b3_orange_ro_v3_9b805
[BB5,XSR 1.6] size: 14.72 MB
Erase size: 75.31 MB
CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
Programming completed in 6.958 s
Total time for flashing process(boot+erase+write) was 1 min 0.399 s
[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C3-00 USB Phonet, PORT_ID: 26E840E6
Verifying communication to device OK.
Phone type: RM-614 (C3-00)
SW version: V 08.70 29-07-11 RM-614 (c) Nokia
Imei plain: 354318043xxxxx-x
Product code: 0594149
Battery voltage: 3973 mV, current: 91 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00BC000004095B1F00, ver: 006.006
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354318043xxxxxx
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.261 s
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Page generated in 0.17949 seconds with 10 queries
