04-27-2011, 12:28 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | C3 incoming call ring dead????????? (ANSWERED) WHEN INCOMING CALL (WITHOUT RECEIVE ) AFTER 3 RING SET DEAD I UPDATE LETEST VER. 08.63 BUT SAME PROBLEM Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) Processing MCU file: rm614__08.63.mcusw [BB5,XSR 1.6] size: 27.90 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 12D6E762 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 00000000000DAD518A20D7533F069B002FA4FCD3 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0010 0011 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 12D6E762 Verifying communication to device OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x178 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.4\data\backup\BB5_35++++++++++++_CE RT.rpl). CMT PAPUBKEYS HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Storing certificate [NPC, CCC, HWC, RND, R&D] OK. Partitioning.... Partitioning complete Erase size: 33.88 MB CMT MuxOneNAND area [00000000-0001FFFF] CMT MuxOneNAND area [00020000-000203FF] CMT MuxOneNAND area [00060000-012FFFFF] CMT MuxOneNAND area [01300000-01DFFFFF] CMT MuxOneNAND area [02600000-029FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 (RAP Certificate v1 232) sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 12.156 s Processing PPM file: rm614__08.63.ppm_r [BB5,XSR 1.6] size: 6.39 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 2.797 s Processing CNT file: rm614__08.63.image_r_0594089 [BB5,XSR 1.6] size: 14.15 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 5.985 s Total time for flashing process(boot+erase+write) was 35.719 s |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
Nokia 6110 without net. couldnīt call 911 either! | DennisT | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-09-2000 11:37 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
New ring tones on 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-23-1999 00:40 |
