12-22-2012, 17:27 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: INDIA
Member: 237007 Status: Offline Thanks Meter: 75 | C5.00.2 usb flashing error Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000B638 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Processing MCU file: rm745_101.003_prd.core.fpsx [BB5,XSR 1.6] size: 97.05 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001060 CMT PUBLIC ID: 256001061AB65A405BDC30CB925C35F9B9A1EA78 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 234F618 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35411505490141_CE RT.rpl). CMT PAPUBKEYS HASH: 5F18D62F8F3D105EEFB6633F44614F8C6DCCA7E8 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 207.56 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0D3BFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 5F18D62F [] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 20.559 s Processing PPM file: rm745_101.003_21.01_India_prd.rofs2.fpsx [BB5,XSR 1.6] size: 31.96 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 65 MB CMT FLASH,MuxOneNAND area [07C40000-0BD3FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 6.941 s Processing PPM file: rm745_101.003_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 5.91 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 22.50 MB CMT FLASH,MuxOneNAND area [0BD40000-0D3BFFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.061 s Processing CNT file: rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx [BB5,XSR 1.6] size: 2.25 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 4 MB CMT FLASH,MuxOneNAND area [004E0000-008DFFFF] Converting UCP blocks to 128 K. Error converting UCP! Task failed at (08000009)!!! Last RX buffer: 80 10 6F 00 How to solve this error ......... |
12-22-2012, 18:04 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Untick Force 128K next to CNT Image File & Reflash it, Must solve it. Use Latest Mxkey Version: http://forum.gsmhosting.com/vbb/f550...hread-1584847/ BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
