01-25-2012, 11:53 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: United Arab Emirates Age: 44
Member: 49226 Status: Offline Thanks Meter: 9 | C5-03 downgrade problem mxkey edition imei is i think intact but security test failed,i have rpl and full pm back up. what is the solution for this problem using hti box..pls help.. customer is angry, its just change language to urdu... |
01-25-2012, 13:49 | #3 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | Quote:
post bus check logs here...then i will help u | |
01-25-2012, 13:56 | #4 (permalink) | |
Member: 49226 Status: Offline Thanks Meter: 9 | Quote:
then phone power on | |
01-25-2012, 17:18 | #5 (permalink) |
No Life Poster Join Date: Apr 2007
Member: 485779 Status: Offline Thanks Meter: 135 | First flash (USB) with 2nd last version it's ok if not and U have simlock & rpl backup don't worry use the FBUS cable Or UFC Cable and write and If SD wrong so repair SD form PM section Regards Last edited by S.Leo; 01-25-2012 at 17:24. |
01-25-2012, 19:50 | #10 (permalink) |
Member: 49226 Status: Offline Thanks Meter: 9 | Version Info: MCU SW version: V ICPR82_11w25.3 24-08-11 RM-697 (c) Nokia HW version: 3092 RFIC version: Vapaus_6.5 Mikki_1.1 DSP version: ICPR82_11w23 Retu version: 35 Tahvo version: 00 APE HW version: 256 APE ADSP SW version: 256 APE BT version: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. WLAN ID: 00 13 DA E3 FC C1 D4 Bluetooth ID: D4 C1 FC E3 CA 73 Product Info: Production serial number: 20CB26BAA Product code: 059C5H2 Module code: 0204650 Basic production code: 059B215 Product specific data: 000000000000000000000000000000000000 Long production SN: 0 Serial Numbers: IMEI plain: 357425046929632 IMEI spare to net: 3A 75 24 05 64 29 69 03 IMEI SV to net: 33 75 24 05 64 29 69 03 F6 Other Info: Model: Nokia C5-03 (Classic Phone) CS type: GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA II/WCDMA VIII Battery voltage: 4801 mV Battery current: 151 mA BSI: 13.5 KOhm Imei net: 357425046929632 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 now i have this one.. PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN whats next?? tma helps me a lot// |
01-25-2012, 20:01 | #11 (permalink) |
Member: 49226 Status: Offline Thanks Meter: 9 | Phone type: RM-697 (Nokia C5-03) SW version: V ICPR82_11w25.3 24-08-11 RM-697 (c) Nokia Imei plain: 35742504692963-2 Product code: 059C5H2 Battery voltage: 4767 mV, current: 187 mA Language Pack: - not available. SLPA ver[5]: PA_SIMLOC30 (20 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! <<<< BUT I HAVE BACK UP RPL AND FULL PM! how can i restore? SUPERDONGLE_KEY[MX] seems to be valid Imei net: 357425046929632 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Selected image is up-to-date Latest software release for Nokia C5-03 is 20.0.024 |
01-25-2012, 20:04 | #12 (permalink) |
Member: 49226 Status: Offline Thanks Meter: 9 | i click write rpl and load back up... this is the logs Imei: 35742504692963 Updating WARRANTY ...OK Updating PRODUCTCODE (059C5H2)... OK Updating PSN (20CB26BAA)... OK Updating HWID (3092)... OK Updating SIMLOCK(PA_SIMLOC30)...OK Updating SUPERDONGLE_KEY ...error 0x14 Updating WMDRM_PD ...OK MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C085138A Using device: HTI, FW ver: 00.50, SN: 000095F3 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 1070000F75F25840A74DE769EA2EA4B49959F2CC ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 3.0 size: 0xD4029 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 78E50A8766EC9CD99D190EEA9676987905B09588 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Prog.status for Asic CMT ... NAND: OK Phone type: RM-697 (Nokia C5-03) SW version: V ICPR82_11w25.3 24-08-11 RM-697 (c) Nokia Imei plain: 35742504692963-2 Product code: 059C5H2 Battery voltage: 4771 mV, current: 188 mA Language Pack: - not available. SLPA ver[5]: PA_SIMLOC30 (20 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid Imei net: 357425046929632 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
01-26-2012, 05:46 | #13 (permalink) |
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | ok....post self test logs.. >u may also try to reset npc, hwc, data first >then erase full flash including pm area >search the latest version flash file for 7 digit your product code & download the flash the phone after that restore imei & write only rpl pm then scan the phone & see whether "security test" FAILED shows.......then just repair sd...thats all post results as it helps u. |
The Following User Says Thank You to rabirabi For This Useful Post: |
01-26-2012, 06:37 | #14 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: bangladesh, dhaka, munshiganj. Age: 37
Member: 570626 Status: Offline Sonork: 100.1579059 Thanks Meter: 129 | Quote:
click sx4 and write server pm or write a good pm WBR shimul. | |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
