06-15-2011, 22:15 | #1 (permalink) |
Freak Poster Join Date: Apr 2011
Member: 1550132 Status: Offline Thanks Meter: 7 | C5 how to recover SDD?(ANSWERED) How to fix this phone? Code: MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 3] - C0672C2D Using device: HTI BOX, FW ver: 00.17 Driver: USBUHCI:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17626(14-06-2011), Library ver: 1.0.0.11296(14-06-2011) CMT Data : SYSTEM ASIC ID: 000220030003022600010007620C192102031104 [RAPU ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0180010512933334BADF0C1F16F724BE6D187E81A ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 9.50.0 revision: 3.0 size: 0x3A40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0098 0040 - 0000 0031 [Toshiba NAND KAT00F00RA] type: MuxOneNAND,CMT Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 9.50.0 revision: 3.0 size: 0x7F29B Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Original Imei: 35433011111111 Original Product code: 01111121 Bluetooth ID: E4EC111111111 SIMLOCK PA identifier: [0] PA_SL3 Phone Type: RM-645 (Nokia C5-00) SW Version: V ICPR82_10w34.2 15-10-10 RM-645 (c) Nokia Imei plain: 35433111111111 Product Code: 01111111 Battery voltage: 4773 mV, current: 0 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3543311111111 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Code: MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 3] - C0672C2D Using device: HTI BOX, FW ver: 00.17 Driver: USBUHCI:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17626(14-06-2011), Library ver: 1.0.0.11296(14-06-2011) Product: V ICPR82_10w34.2 15-10-10 RM-645 (c) Nokia ApeCoreSw: 061.005 SYSTEM ASIC ID: 000000010000022600110007600C191102011104 [RAPU ver: 1.1] ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.10.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 When will the upgrade program? when can be to repair SDD on all phones? |
06-15-2011, 22:30 | #2 (permalink) |
Member: 1550132 Status: Offline Thanks Meter: 7 | Is also the program cant create LOG file for Bruteforce-unlock sl3 on C5 with HASH: 916F75217F32081248B15C38DFC8E81B Code: MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 3] - C0672C2D Using device: HTI BOX, FW ver: 00.17 Driver: USBUHCI:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17626(14-06-2011), Library ver: 1.0.0.11296(14-06-2011) Product: V ICPR82_10w34.2 15-10-10 RM-645 (c) Nokia ApeCoreSw: 061.005 SYSTEM ASIC ID: 000000010000022600110007600C191102011104 [RAPU ver: 1.1] ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.10.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 |
06-16-2011, 15:12 | #3 (permalink) |
Member: 1550132 Status: Offline Thanks Meter: 7 | 5530 SUPERDONGLE_KEY invalid! MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 6] - Using device: HTI BOX, FW ver: 00.17 Driver: USBOHCI:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17626(14-06-2011), Library ver: 1.0.0.11296(14-06-2011) Code: Product: V ICPR72_10w04.5 22-03-10 RM-504 (c) Nokia ApeCoreSw: V 30.0.009 Using cached productData. PUBLIC ID: 0D000102DE9C0052C64E8ABE8312A1A3E5E42508 PRIVATE ID: 0B449164B6EA75C5A295F64FD532EDC565B48FFA E-FUSE: 04809487 SEC ROM CRC: 3E691FF8 Updating SUPERDONGLE_KEY ...error 0x0 Authenticating to SUPERDONGLE ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
06-16-2011, 15:15 | #4 (permalink) |
Member: 1550132 Status: Offline Thanks Meter: 7 | n97 mini info not coret buton "Scan" Code: Phone Type: RM-555 (Nokia N97 mini) SW Version: V ICPR72_09w44.18 28-05-10 RM-555 (c) Nokia Imei plain: 35339104242864-5 Product Code: 0585099 Battery voltage: 4684 mV, current: 0 mA ApeCoreSw: v 12.0.110 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353391042428645 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Code: MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 6] - Using device: HTI BOX, FW ver: 00.17 Driver: USBOHCI:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17626(14-06-2011), Library ver: 1.0.0.11296(14-06-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0570011913970052FF63D1B0DA9C5F7D4C25921B ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0058 - 0000 0121 [Samsung ] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.10.0 revision: 2.0 size: 0x875B6 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: C49131EB98702B6A39D7F285B1FF2D9BE1D6F863 Original Imei: 35339104242864 Original Product code: 0585099 Bluetooth ID: 20D60783A2CC SIMLOCK PA identifier: [0] PA_SL3 Phone Type: RM-555 (Nokia N97 mini) SW Version: V ICPR72_09w44.18 28-05-10 RM-555 (c) Nokia Imei plain: 35339104242864-5 Product Code: 0585099 Battery voltage: 4729 mV, current: 0 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed:D:confused: SECURITY_TEST passed Imei net: 353391042428645 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Last edited by Stincks; 06-16-2011 at 15:21. |
06-26-2011, 21:25 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, please delete your current mobileex directory. install 3.5 rev.1.2, do app sign, do synchronize files. repeat operation. rapu and rap4 should be done without any problem on HTI. |
06-27-2011, 15:23 | #9 (permalink) | |
Insane Poster Join Date: Sep 2005 Location: rus Age: 42
Member: 178272 Status: Offline Thanks Meter: 93 | Quote:
old phones work well waiting for the new model phones | |
06-28-2011, 18:16 | #10 (permalink) | |
C5 with memory FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND I got make repaer SD but I have a phone C5 with memory Toshiba [Toshiba NAND KAT00F00RA] and with this memory does not work repaer SD! Why Memory Toshiba repaer not happen? please fix this bug and 5530 tooo | |
06-30-2011, 15:54 | #11 (permalink) | |
which problems with memory Toshiba? | |
The Following User Says Thank You to roman_-_666 For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
