Old 10-11-2012, 01:42   #1 (permalink)
austinejiasa's Avatar
Member: 1149419
Sonork: NIL
Thanks Meter: 52
Arrow C6-00 dead,need help pls.
it only vibrates but does not power on.i have done wt i should do but no success. See attachment.also it does not enter local mode.
The Following User Says Thank You to austinejiasa For This Useful Post:
Old 10-11-2012, 06:04   #2 (permalink)
Member: 1149419
Sonork: NIL
Thanks Meter: 52
no help forum members?
Old 10-11-2012, 09:57   #3 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,263
Before playing in Software, Reflow Flash IC & Check,
If not solve, post reply.
Will try to resolve it in Software.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 10-11-2012, 13:56   #4 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,137
I tested solution solved your problem flash with dead usb post log here.
BR.
Arsalan gsm2000.
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Old 10-11-2012, 22:52   #5 (permalink)
Member: 1149419
Sonork: NIL
Thanks Meter: 52
SEE USB LOG.
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C08067FA
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100ADEA
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Processing MCU file: RM-612_42.0.004_prd.core.C00
[BB5,XSR 1.6] size: 111.93 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 19D00115DB8B10528BCDD7F594D55F2CDBDC98A3
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 207.44 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0D39FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 505A5C85 [RAP Certificate v1 228] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 2 min 35.110 s
Processing PPM file: RM-612_42.0.004_prd.rofs2.V29
[BB5,XSR 1.6] size: 31.35 MB
Erase size: 48 MB
CMT FLASH,MuxOneNAND area [094A0000-0C49FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 44.703 s
Processing PPM file: RM-612_42.0.004_C01_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 7.96 KB
Erase size: 15 MB
CMT FLASH,MuxOneNAND area [0C4A0000-0D39FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 0.031 s
Processing CNT file: RM612_APE_ONLY_ENO_11w42_v0.020.fpsx
[BB5,XSR 1.6] size: 2.68 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT SOS*ENO block sent
Programming completed in 3.812 s
Processing CNT file: RM-612_42.0.004_uda_2_001.uda.fpsx
[BB5,XSR 1.6] size: 56.79 MB
Erase size: 283.75 MB
CMT FLASH,MuxOneNAND area [0D3C0000-1EF7FFFF]
Programming completed in 1 min 26.000 s
Total time for flashing process(boot+erase+write) was 5 min 4.157 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
Old 10-13-2012, 13:45   #6 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,137
SEE USB LOG.
Partitioning....
CMT ADA block sent
CMT KEYS block sent
Erase size: 48 MB
Erase size: 15 MB
Erase size: 4 MB
You flash with without ENO file like 3 files write only and must be same your product code.
BR.
Arsalan gsm2000.
Old 10-13-2012, 14:22   #7 (permalink)
Crazy Poster
Member: 1351426
Thanks Meter: 8
use rm-624 i think ur problem will be solved
Old 10-13-2012, 19:15   #8 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,137
You are spam?why you guide is wrong is type RM-612 why flash with rm-624 your spam way now totally damage phone.
BR.
Arsalan gsm2000.
Page generated in 0.32545 seconds with 8 queries
