Old 10-06-2012, 14:45   #1 (permalink)
manule's Avatar
Member: 786607
Thanks Meter: 66
help wit 6700c rpl
see log pls
help to write rpl and finally working phone again
have usb
Old 10-06-2012, 14:57   #2 (permalink)
manule's Avatar
Member: 786607
Thanks Meter: 66
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C086
Using device: USB ROM and HTI, FW ver: 00.50, SN: 010057F2
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C34
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 13F0000A6A620344A8CA77DFE7DD088512AF3147
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
CMT ROM ID: 3E273BF637BE26FA
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1217D0D9
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6
Selected firmware certificate matched.
Original Imei: 35823803041606
Original Product code: 0586955
Bluetooth ID: 1886AC4C68CB
SIMLOCK PA identifier:
[0] PA_SL3
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 6700 classic USB Phonet, PORT_ID: 121C6E59
Verifying communication to device OK.
Phone type: RM-470 (Nokia 6700 classic)
SW version: V 13.21 12-01-11 RM-470 (c) Nokia
Imei plain: 35823803041606-3
Battery voltage: 3533 mV, current: 271 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
Old 10-06-2012, 17:14   #3 (permalink)
rahulgsm7's Avatar
Member: 1810350
Sonork: 8888888
Thanks Meter: 9
right the rpl in the same imei in your backup then ubedare the simlock..........
uschak the replay
Old 10-06-2012, 18:35   #4 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
[0] PA_SL3
Language Pack:
- not available.
SIMLOCK invalid!
[0] PA_SL3 It's sl3 phone not fix at this time simlock corrupted and restore backup but same simlock corrupted it's mean already corrupted your backup it's only one solution BUY new one RPL.
BR.
Arsalan gsm2000.
Page generated in 0.18163 seconds with 8 queries
