Old 10-06-2012, 15:10   #1 (permalink)
austinejiasa's Avatar
Member: 1149419
Sonork: NIL
Thanks Meter: 58
C6-00 erase error.please help
My c6-00 dead after flash with usb.tried to fully erase and reflash but see picture
Old 10-06-2012, 18:00   #2 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Already chip blank/erase why you erase flash.
what's the condition of phone.
post here you are face problem.
BR.
Arsalan gsm2000.
Old 10-06-2012, 19:25   #3 (permalink)
Member: 1149419
Sonork: NIL
Thanks Meter: 58
Actually it is my personal phone. I powered it 2 days ago and it came on and went off.i thought it was battery but after charging battery ful it repeated so i flashed it but it refused to enter local mode,then i erased wt infinity best bf mxbox. Right nw if u press power it wl just vibrate and nothing else.pls help me.thanks.
Old 10-06-2012, 19:47   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Post Buscheck Logs,
Have you taken Backup RPL All Sections before Erase?
If taken, then follow Erase from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ ,
Download Latest Firmware of your Phone Product Code & Flash it,
Write PM & then Restore IMEI,
Make Full Reset must work for you.
Good Luck.
BR,
ZUBER
Old 10-07-2012, 01:32   #5 (permalink)
Member: 1149419
Sonork: NIL
Thanks Meter: 58
Thanks but i just did exactly as u asked me but i has refused to enter local mode. Both with fbus and usb cables. Pls do u have any more suggested solutions?
Old 10-07-2012, 01:47   #6 (permalink)
Member: 1149419
Sonork: NIL
Thanks Meter: 58
@ ZUBBA,THIS IS BUSCHECK LOG.
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C08067FA
Using device: HTI, FW ver: 00.50, SN: 0100ADEA
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 19D00115DB8B10528BCDD7F594D55F2CDBDC98A3
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 505A5C85580A6322C103BFE4E67B73EF478E791C
Original Imei: Empty
Original Product code: Empty
NPC_DATA invalid !
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Old 10-07-2012, 01:49   #7 (permalink)
Member: 1149419
Sonork: NIL
Thanks Meter: 58
Arrow X2-01 not power after flash.
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100ADEA
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Processing MCU file: rm709__08.71.mcusw
[BB5,XSR 1.6] size: 26.61 MB
Supported Ids: 2200050920030000, 22000509200C0000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1ACE961
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 0000000000D683D507CCD16CA6B72C5E97485E5B
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
Secondary boot loaded.
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35791504089894_CE RT.rpl).
CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 33.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT ADA block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 37955B6F [] sent
CMT UPDAPP block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 12.312 s
Processing PPM file: rm709__08.71.ppm_mh1
[BB5,XSR 1.6] size: 6.53 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
Programming completed in 6.547 s
Processing CNT file: rm709__08.71.image_mh1_059D365
[BB5,XSR 1.6] size: 23.91 MB
Erase size: 75.31 MB
CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
Programming completed in 22.609 s
Total time for flashing process(boot+erase+write) was 1 min 18.156 s
Waiting for device boot up ...
Warning: Phone did not reboot to normal mode.
[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
Page generated in 0.18180 seconds with 9 queries
