Member: 172261
Thanks Meter: 364 | C6-00 show Nokia and restart Quote:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0808080
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 00002BBB
Connection status: EHCI:HUB:HUB:USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.75
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Reading Important data ...
NPC_DATA is empty.
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_3569940xxxxxxx_PM .rpl"
Processing MCU file: RM-612_42.0.004_prd.core.C00
[BB5,XSR 1.6] size: 111.93 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Battery voltage: 3667 mV
Warning battery voltage is less, phone might not detected after flash !
Phone type: RM-612 (Nokia C6-00)
Product code: 0597935
SW version: v 42.0.004
LanguagePkg version: v 42.0.00442.0.004.32.0142.0.004.C01.01
Version from phone: v
Version from file: 42.0.004
Waiting for USB device removal ...
Waiting for USB ROM device ...
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 0660010A2FFE02520781F153BBD60A239DB60FEA
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 207.44 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0D39FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 505A5C85 [RAP Certificate v1 228] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 1 min 55.558 s
Processing PPM file: RM-612_42.0.004_prd.rofs2.V32
[BB5,XSR 1.6] size: 37.06 MB
Erase size: 48 MB
CMT FLASH,MuxOneNAND area [094A0000-0C49FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 42.572 s
Processing PPM file: RM-612_42.0.004_C01_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 7.96 KB
Erase size: 15 MB
CMT FLASH,MuxOneNAND area [0C4A0000-0D39FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 0.052 s
Processing CNT file: RM612_APE_ONLY_ENO_11w42_v0.020.fpsx
[BB5,XSR 1.6] size: 2.68 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT SOS*ENO block sent
Programming completed in 3.687 s
Processing CNT file: RM-612_42.0.004_uda_11_001.uda.fpsx
[BB5,XSR 1.6] size: 56.88 MB
Erase size: 283.75 MB
CMT FLASH,MuxOneNAND area [0D3C0000-1EF7FFFF]
Programming completed in 1 min 8.380 s
Total time for flashing process(boot+erase+write) was 4 min 32.890 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: 1E5FDA84
Verifying communication to device OK.
SW version: V ICPR72_11w16.3 05-12-11 RM-612 (c) Nokia
ApeCoreSw: v 42.0.004
Imei plain: 3569940xxxxxxx-8
Battery voltage: 3664 mV, current: 302 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3569940xxxxxxxx
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 7.481 s
after flash still show NOKIA only on startup and keep restart (white screen >> NOKIA >> restart) |
