06-07-2013, 13:08 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1231601 Status: Offline Thanks Meter: 13 | c6.01.3 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0856E16 Using device: USB ROM and HTI, FW ver: 00.50, SN: 00005C74 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: RM-718_111.040.1511_79u_prd.core.fpsx [BB5,XSR 1.6] size: 122.87 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 07200217A9A6034481BA75B5E06976B77EF5CD51 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0068 - 0000 0131 [Samsung LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x178 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35375904190159_CE RT.rpl). CMT PAPUBKEYS HASH: C436DE8B3DEA6D6C6CCE9CBE15F7C501BB822D02 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 474.56 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0DAFFFFF] CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT SOS+DECOMP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: C436DE8B [RAP Certificate 221 Ver] sent CMT GENIO_INIT block sent CMT SOS+IVE3A block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 39.906 s Processing PPM file: RM-718_111.040.1511_01.01_Euro1_79u_prd.rofs2.fpsx [BB5,XSR 1.6] size: 55.78 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [090C0000-0CBFFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 15.938 s Processing PPM file: RM-718_111.040.1511_C21.01_Skip_Cherry_79u_prd.rofs3. fpsx [BB5,XSR 1.6] size: 27.18 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15.16 MB CMT FLASH,MuxOneNAND area [01378000-0139FFFF] CMT FLASH,MuxOneNAND area [0CC00000-0DAFFFFF] Flash programming ... CMT SOS+ROFS3 block sent CMT SOS+IVE3B block sent Programming completed in 0.063 s Processing CNT file: RM601_APE_ONLY_ENO_11w32_v0.064.fpsx [BB5,XSR 1.6] size: 4.84 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 1.218 s Processing CNT file: RM-718_111.040.1511_U01.01_79u.uda.fpsx [BB5,XSR 1.6] size: 211.94 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 518 MB CMT FLASH,MuxOneNAND area [0DB00000-2E0FFFFF] Flash programming ... WriteDevice failed: Overlapped I/O operation is in progress Error while programming [00] at 0x0F880000, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: 80 10 6F 00 help |
06-07-2013, 14:34 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. What was the phone condition before Flashing, Is it Physically damage, You can confirm from the owner, Please reply. BR, ZUBER |
