Old 10-18-2012, 17:13   #1 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 262
c6 no power, only logo nokia and restart
My c6 no power, only logo nokia and restart
Connection status: OHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Processing MCU file: RM-601_111.030.0609_79u_prd.core.fpsx
[BB5,XSR 1.6] size: 119.73 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 20D00111BAA60344AF2FF060190099CE5034DC94
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0068 - 0000 0131 [Samsung LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1D6F746F
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x0 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x0 bytes).
Reading CMT HWC (0x0 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Invalid Certificate Data, backup will not be created.
Error saving backup !
CMT PAPUBKEYS HASH: C436DE8B3DEA6D6C6CCE9CBE15F7C501BB822D02
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning....
Partitioning complete
Erase size: 474.56 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-0DAFFFFF]
CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT SOS+DECOMP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: C436DE8B [RAP Certificate 221 Ver] sent
CMT GENIO_INIT block sent
CMT SOS+IVE3A block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 15.438 s
Processing PPM file: RM-601_111.030.0609_13.01_APAC1_79u_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 46.78 MB
Erase size: 59.25 MB
CMT FLASH,MuxOneNAND area [090C0000-0CBFFFFF]
CMT SOS+ROFS2 block sent
Programming completed in 6.032 s
Processing PPM file: RM-601_111.030.0609_C02.01_SEAP_79u_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 22.67 KB
Erase size: 15.16 MB
CMT FLASH,MuxOneNAND area [01378000-0139FFFF]
CMT FLASH,MuxOneNAND area [0CC00000-0DAFFFFF]
CMT SOS+ROFS3 block sent
CMT SOS+IVE3B block sent
Programming completed in 0.031 s
Processing CNT file: RM601_APE_ONLY_ENO_11w32_v0.064.fpsx
[BB5,XSR 1.6] size: 4.84 MB
Erase size: 5 MB
CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF]
CMT SOS*ENO block sent
Programming completed in 0.625 s
Processing CNT file: RM-601_111.030.0609_U08.01_79u.uda.fpsx
[BB5,XSR 1.6] size: 146.21 MB
Erase size: 518 MB
CMT FLASH,MuxOneNAND area [0DB00000-2E0FFFFF]
Programming completed in 22.203 s
Total time for flashing process(boot+erase+write) was 1 min 1.000 s
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
Old 10-18-2012, 19:25   #2 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,136
Partitioning....
CMT ADA block sent
CMT KEYS block sent
CMT LDSP block sent
Erase size: 5 MB
Erase size: 518 MB
Are you sure phone type is RM-601 OR RM-612.
No Regards.
Old 10-18-2012, 20:32   #3 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 262
This is rm-601, I try with rm-612?
Old 10-18-2012, 20:59   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Bro.
If you Backup All,
Then follow Erase from here: HTI On USB, what this box can do?,
Flash with Latest Firmware of RM-601 with same Product Code of your Phone.
Good Luck.
BR,
ZUBER
Page generated in 0.23257 seconds with 7 queries
