08-12-2012, 13:15 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: kerala india
Member: 952533 Status: Offline Sonork: 1001607366 Thanks Meter: 124 | MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0873462 Using device: USB ROM and HTI, FW ver: 00.50, SN: 01007DC2 Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Processing MCU file: RM-675_111.030.0609_79u_prd.core.fpsx [BB5,XSR 1.6] size: 120.12 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 12500203E1DD0344442E4588E94BDEDA9532F79D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0060 - 0000 0032 [Samsung LH28F800BG] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 63AEC3C FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 489.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT SOS+DECOMP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 95A68E9F [RAP Certificate v1 263] sent CMT GENIO_INIT block sent CMT SOS+IVE3A block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 2 min 24.829 s Processing PPM file: RM-675_111.030.0609_02.01_Euro2_79u_prd.rofs2.fpsx [BB5,XSR 1.6] size: 53.10 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 1 min 3.968 s Processing PPM file: RM-675_111.030.0609_218.01_default_79u.2011.44_prd.ro fs3.fpsx [BB5,XSR 1.6] size: 18.98 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15.16 MB CMT FLASH,MuxOneNAND area [01378000-0139FFFF] CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF] Flash programming ... CMT SOS+ROFS3 block sent CMT SOS+IVE3B block sent Programming completed in 0.063 s Processing CNT file: rm675_ENO_v_0.0514_APEONLY.fpsx [BB5,XSR 1.6] size: 4.73 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 5.656 s Processing CNT file: RM-675_111.030.0609_U01.01_79u.uda.fpsx [BB5,XSR 1.6] size: 153.90 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 503.50 MB CMT FLASH,MuxOneNAND area [0E980000-2E0FFFFF] Flash programming ... Programming completed in 3 min 10.375 s Total time for flashing process(boot+erase+write) was 7 min 4.360 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying .. |
08-12-2012, 17:11 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Go to Service Tab> Quick Fix Tab> Tick BB5 SW Downgrade Fix> Click Do Selected Job will solve it. If not solve then follow full Erase Method from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ Have you taken Full Backup ? it is must for above operation. BR, ZUBER |
08-13-2012, 07:06 | #9 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | You have not taken Full Backup. So only option is Bro. Go to Service Tab> Quick Fix Tab> Tick BB5 SW Downgrade Fix> Click Do Selected Job, after Quick Fix Flash it with Latest Firmware of your Phone Product will solve it. BR, ZUBER |
08-13-2012, 10:25 | #10 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | what was the phone's status before flashing? how do u know u have downgraded it? phone was alive before and u can check phone's version? then, why u downgrade it? im confused n curious bro br |
08-13-2012, 17:41 | #11 (permalink) |
Member: 952533 Status: Offline Sonork: 1001607366 Thanks Meter: 124 | before i flash phone was working condition, just for update, but in 111.0610 only two varients & ovi vot working, so i downgrade to 111.0609, now phone nokia logo only & no local mode exist and i again flash to 111.0610, now get read info every thing is ok in read info, but phone nokia then light go, just keypad light working, how to solve this problem, plz help me mx team |
08-13-2012, 18:09 | #12 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Go to Service Tab & Backup all Important data like Backup RPL, PM, Sim RPL. Due to Info. Ok now you can do this all Backup without Error. Now Use Trick & Follow Erase from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ & after Erase, Flash with Lowest Version Firmware of your Phone Product only, after Restoring all Backups Phone will work OK. Again Flash but with Latest Belle Version Firmware of your Phone Product only, let it be V111.030.0609 or 610 but with same Product. ENJOY BR, ZUBER | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
08-14-2012, 17:22 | #14 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Ya! That's sound nice, now you can Flash Belle Version with your Product Firmware will work fine now. BR, ZUBER |
