02-04-2010, 10:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | still have bug on dct4 unit, use ufs interface bus check Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! scan Phone Type: RH-64 SW Version: V 7.02 10-12-07 RH-64 (c) NMP Imei plain: 35204902308298-6 Product Code: 0525378 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: AC Language Pack: English,Danish,Icelandic Imei net: 35204902308298 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.CORRUPTED (20) 4.CORRUPTED (20) 5.CORRUPTED (20) Flashing Using device: UFS_USB V2.8 (c) SarasSoft 2007.Library version: 1.0.0.11985, Date: 03-02-2010Rpl backup already exist. Processing file: rh64_07.020 as MCU [DCT4,DCT4 ALGORITHM] size: 1.84 MBSupported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2]SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! flashing terminated ! Flashing terminated with error(s) in 46.062 s RX Buffer: D372 unlock Imei net: 35204902308298 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.CORRUPTED (20) 4.CORRUPTED (20) 5.CORRUPTED (20) Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35204902308298 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN hope fix this soon |
02-09-2010, 13:55 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | me too face this problem while flashing with ufs here is the logs.. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! Processing file: rh19__06.010 as MCU [DCT4,DCT4 ALGORITHM] size: 5.27 MB Supported Ids: 0120, 1120, 2140, 2141 ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! flashing terminated ! Flashing terminated with error(s) in 1 min 47.063 s RX Buffer: D372 what kind of this error is it flashing cable problem or what... |
3.3 rev1.7 can`t flash 2330 and have bug with dct4 loader | panafax_gsm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 03-19-2010 00:57 |
MXKey errors when using UFS interface | mishaelwillo | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-01-2010 22:39 |
mx-team still having bugs | sunny_luthras99 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-02-2010 06:45 |
LG ks360 imie repair still have bugs ::: ANSWERED ::: | sameenshah123 | PolarBox 3 | 12 | 03-22-2009 21:40 |
