01-26-2010, 15:04 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | can i unlock this 2610b Library version: 1.0.0.11866, Date: 26-01-2010 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004F2103:3B8ADA60 ASIC type: 11 UEM Imei: 01175000080894 Flash Imei: 01175000080894 MasterCode: 3223000261 RPL saved to "C:\mobileEx\3.3\data\backup\01175000080894_BACK.r pl" Phone Type: RH-87 (Nokia 2610) SW Version: V 07.04a 26-08-08 RH-87 (c) Nokia. Imei plain: 01175000080894-6 Imei OTP: 01175000080894 Product Code: 0567579 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: MCR Language Pack: - not available. Imei net: 01175000080894 Version: SIMLOCK SERVER Provider: CINGULAR - Pacific Bell Wireless, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3101700000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 310150 BLOCK 2: 1.LOCKED (MCC+MNC): 310170 BLOCK 3: 1.LOCKED (MCC+MNC): 311180 BLOCK 4: 1.LOCKED (MCC+MNC): 310410 BLOCK 5: 1.LOCKED (MCC+MNC): 310980 |
01-26-2010, 15:11 | #3 (permalink) |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | Imei net: 01175000080894 Version: SIMLOCK SERVER Provider: CINGULAR - Pacific Bell Wireless, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3101700000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 310150 BLOCK 2: 1.LOCKED (MCC+MNC): 310170 BLOCK 3: 1.LOCKED (MCC+MNC): 311180 BLOCK 4: 1.LOCKED (MCC+MNC): 310410 BLOCK 5: 1.LOCKED (MCC+MNC): 310980 PhoneType:RH-87 SwVersion: V 07.04a 26-08-08 RH-87 (c) Nokia. MCU file: rh87__07.04a.mcusw Trying to find patch position ...Sorry, no routine found or not supported model ! ------------------ i try to unlock this problem in face |
01-26-2010, 16:18 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | Quote:
Fight for nothing ,as i am here to help others. Every dct4 phone could be unlocked by downgrading with supported version.So what it means ? Unsupported are also only you needs to downgrad(flash etc) and then Unlock. Regards, Umair | |
The Following User Says Thank You to Umair Rashid For This Useful Post: |
01-26-2010, 16:28 | #8 (permalink) |
Freak Poster Join Date: May 2008 Location: Philippines
Member: 783116 Status: Offline Thanks Meter: 52 | downgrading this kind of firmware version will lead to dead phone only UB cyclone and nebula can unlock at this moment regards Last edited by tandaganon; 01-26-2010 at 16:38. |
The Following User Says Thank You to tandaganon For This Useful Post: |
01-26-2010, 16:35 | #9 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | Quote:
01-26-2010, 16:39 | #10 (permalink) | |
i did many sets like 2600 and 2630 with even HWK by that way. It's my experience, anyway leave this War. | |
01-26-2010, 16:42 | #11 (permalink) |
No Life Poster Join Date: Mar 2008 Location: hungphongmobile.vn
Member: 733209 Status: Offline Sonork: 1001620525 Thanks Meter: 426 | Not suported by Mxkey please fix or Use other tool UB,MT unlocking it ok etc ... tested ok by me |
The Following User Says Thank You to hung phong For This Useful Post: |
01-26-2010, 16:47 | #13 (permalink) | |
i m also talking about this 2610b dct4+ fone better try search b4 advise | |
01-26-2010, 16:56 | #14 (permalink) |
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | I am there to help others. My Each and every advice are Correct .You can see all my previous posts and History. *To the point answers. *Valid answers. *Instant help ,and *Right knowledge. If you don't find it worth reading don't argue better keep your comments away. No regards, Umair |
01-26-2010, 16:57 | #15 (permalink) | |
No Life Poster Join Date: Apr 2009
Member: 1009679 Status: Offline Thanks Meter: 166 | Quote:
it's not theory it was my personal experience | |
How can I unlock this Samsung L760v? I canīt see codes:::ANSWERED::: | Grupo MovilFree | PolarBox 3 | 13 | 09-01-2009 20:06 |
T725 can SC unlock this? | Hagan | Motorola P2k | 0 | 06-15-2005 14:29 |
p910i unlock???? can cruiser unlock this fon??? | kcgckc2002 | Cruiser Suite | 7 | 03-01-2005 01:04 |
Can vygis unlock this | filipas | VygisToolbox | 1 | 01-28-2005 22:11 |
can you unlock this ATT 3650? | greasyheart | Phone Unlocking Codes & Maps | 6 | 07-19-2003 22:37 |
