Old 06-21-2009, 08:44   #1 (permalink)
milandhal's Avatar
Member: 508774
Sonork: 100.1590207
Thanks Meter: 207
Can mx key flash nokia 1202 ?
Pl z moderator tell me ?
I have 5 set contact service ?
I want flashing 1202
thanks in advance
Old 06-21-2009, 08:52   #2 (permalink)
stan1comm's Avatar
Member: 609952
Sonork: 100.1574492
Thanks Meter: 154
yes it,s will do
br
stan1comm
Old 06-21-2009, 08:55   #3 (permalink)
rajufzr's Avatar
Member: 116314
Thanks Meter: 147
and how to reset security code 1202 with mxkey. is it same as doing normal nokia phones.
Old 06-21-2009, 09:58   #4 (permalink)
Member: 619475
Thanks Meter: 63
yes off course
br,
The Following User Says Thank You to ags_nadhif For This Useful Post:
Old 06-21-2009, 10:01   #5 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
thanks in advance
rh-111 or rh-112
if nokia 1202/1203 rh-111 is not supported for flash
nokia rh-112 supported for flash.
HTALDAR
The Following User Says Thank You to himanshu taldar For This Useful Post:
Old 06-22-2009, 08:18   #6 (permalink)
milandhal's Avatar
Member: 508774
Sonork: 100.1590207
Thanks Meter: 207
ok thanks for info
when support 1202/1203 rh-111 ?
can u 1202/1203 rh-111 support in next update ?
plz sir we need this
Old 06-23-2009, 10:24   #7 (permalink)
Alim Hape's Avatar
Member: 43548
Thanks Meter: 2,192
ok thanks for info
Hi,
sorry, we dont have this phone in APAC.
if you have the firmware, let me know so i can manage to support in next release.
BR.
Old 06-23-2009, 17:02   #8 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Originally Posted by himanshu taldar View Post
rh-111 or rh-112
HTALDAR
Hi,
Because Rh-111 is INFINEON CPU not Nokia UPP, it can't be flash by any device yet
RH-112 is Same as other nokia phone ,Nokia UPP .
The Following 4 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 06-24-2009, 07:32   #9 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Originally Posted by i-mobile View Post
Hi,
BR.
@i-mobile
FLASHING 1202 OR 1203 IS NOT POSSIBLE BUT WHEN WE CHECK INFO ITS SHOWN EASILY HOPE U CAN SUPPORT THIS MODEL.
I HAVE THE FIRMWARE WITH ME WITH ALL LATEST RELEASES IF U WANT I CAN SEND IT TO U FOR FURTHER ANALYSIS
WBR
sahil2000ind
Old 06-25-2009, 07:11   #10 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
not possible except..nokia care suit
The Following User Says Thank You to akhil_bbsr For This Useful Post:
Old 06-25-2009, 19:32   #11 (permalink)
Member: 205475
Thanks Meter: 179
man i have nokia 1202 rh-112 i flashing it and write pm file but unlock not complet always give error and give message that make undo the unlock operation
Old 06-26-2009, 03:38   #12 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
yes,
nut support yet
br,
Old 02-10-2011, 10:59   #13 (permalink)
Member: 337100
Sonork: 100.1606722
Thanks Meter: 75
ALIM sir i cant flash 1202(rh111) from mx-key 3.4 rev1.8.....
plssssss add infineon plateform in next release......
like 1202 1203 c-1 c-2 1616......
Old 02-10-2011, 11:07   #14 (permalink)
Member: 787818
Thanks Meter: 4
yes u can flash it on MxKey but if it is on Contact Service just Update Simlock!....
sometime its gone on contact service becoz of it's LCD. try to get Phone Info by MxKey. if LCD Version is Unknown then its LCD problem.
HELLO MX-TEAM ! Can MX-KEY Solve 2630 Contact Service? amit123 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 13 09-13-2010 22:05
Can MX KEY unlock the new firm v40 of nokia 5800?? puntodecontrol MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 01-16-2010 16:36
mx key give the 1202 unlocking all users are waiting diljankhan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 12-13-2009 15:54
can mx-key use with box"DCT4 DIRECT BOX" khunv MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 05-10-2009 16:46
how can i flash nokia 1202 with ufs jkniji Nokia Hardware & Hardware Repair 0 04-25-2009 14:47
Page generated in 0.22361 seconds with 9 queries
