02-21-2010, 06:32 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | can not flash 1202[SOLVED, CABLE PROBEM] Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\35935203226893_BACK.r pl). Processing file: rh112_004.030 as MCU [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0075489A:2984DA60 Area [01000000-0100FFFF] erased in 1.235 s Area [01010000-013AFFFF] erased in 1 min 14.187 s Area [013B0000-013EFFFF] erased in 5.203 s Area [017C0000-017EFFFF] erased in 0.046 s Area [01FC0000-01FEFFFF] erased in 0.063 s Flash programming ... Programming completed in 16.485 s File Processed in 1 min 48.969 s Processing file: rh1120_nai04.03md as CNT [DCT4,DCT4 ALGORITHM] size: 130.39 KB Supported Ids: 2293 Boot error: 4F 4E 00 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 2 min 43.844 s RX Buffer: 0200 usig fbus cable Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Boot error: 4F 4E 00 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Processing file: rh112_004.030 as MCU [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 Boot error: 4F 4E 00 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 1 min 51.500 s Last edited by hooi76; 02-21-2010 at 06:39. |
02-21-2010, 08:17 | #3 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | i solve with fbus cable. connecction problem, but easy cable still not working |
The Following 2 Users Say Thank You to hooi76 For This Useful Post: |
KM900 can not flash [Solving] | karikari | Z3X-Team Products | 21 | 10-23-2009 15:57 |
lgu960 can not make contact [Solving] | supportallgsm | Z3X-Team Products | 3 | 09-09-2009 11:10 |
can not fill credits - SOLVED | sandrea | Cyclonebox | 2 | 08-01-2009 11:31 |
can i flash 1202 rh111 using cyclone? | zonetrichur | Cyclonebox | 4 | 07-15-2009 07:22 |
