02-14-2010, 19:53 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Location: MA
Member: 52763 Status: Offline Thanks Meter: 35 | can repaire MX-KEY Nokia N900 SW Version: 1.2009.44.1.003 RX-51_2009SE_1.2009.44-1.003_PR_003 RX-51 (c) No Imei plain: 35xxxxxxxxxxxxxxxxxxxx Product Code: 0582647 ApeCoreSw: 1.2009.44.1.003 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2009-12-22T07:23:57+00:00 SW Version: 2.2009.51.1 Variant Version: 001 ProductProfile: Simlock: simlock_3gstandard_bb5.bin Imei net: 35xxxxxxxxxxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-14-2010, 19:58 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Algeria
Member: 695274 Status: Offline Thanks Meter: 814 | this is SL3 phone!!!!!!!!!!!!!! and you have SIMLOCK invalid! you c'ant repaire simlock for sl3 now only with RPL from nokia or wait the next updat............... |
02-14-2010, 20:09 | #3 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: MX-KEY is the BEST NOKIA TOOL Age: 42
Member: 888048 Status: Offline Sonork: 123 Thanks Meter: 30 | Quote:
02-15-2010, 09:51 | #5 (permalink) |
Member: 52763 Status: Offline Thanks Meter: 35 | ok with flash maemo flasher-3.5 cd "c:\Program Files\maemo\flasher-3.5" flasher-3.5.exe -F RX-51_2009SE_2.2009.51-1.003_PR_F5_003_ARM.bin -f - flasher-3.5.exe -F RX-51_2009SE_1.2009.42-11_PR_COMBINED_MR0_ARM.bin -f -R Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. H:\Program Files\maemo\flasher-3.5>flasher-3.5.exe -F RX-51_2009SE_1.2009.42-11_ PR_COMBINED_MR0_ARM.bin -f -R flasher v2.5.2 (Sep 24 2009) SW version in image: RX-51_2009SE_2.2009.51-1.003_PR_003 Image 'kernel', size 1704 kB Version 2.6.28-20094803.3+0m5 Image 'rootfs', size 153344 kB Version RX-51_2009SE_2.2009.51-1.003_PR_003 Image 'cmt-2nd', size 81408 bytes Version BB5_09.36 Image 'cmt-algo', size 519808 bytes Version BB5_09.36 Image 'cmt-mcusw', size 5824 kB Version rx51_ICPR82_09w47 Image '2nd', size 14720 bytes Version 1.4.14.2+0m5 Image 'xloader', size 14848 bytes Version 1.4.14.2+0m5 Image 'secondary', size 109440 bytes Version 1.4.14.2+0m5 USB device found found at bus bus-0, device address \\.\libusb0-0002--0x0421-0x0 105. Found device RX-51, hardware revision 2101 NOLO version 1.4.13 Version of 'sw-release': RX-51_2009SE_1.2009.44-1.003_PR_003 Sending xloader image (14 kB)... 100% (14 of 0 kB, avg. 14 kB/s) Sending secondary image (106 kB)... 100% (106 of 0 kB, avg. 106 kB/s) Flashing bootloader... done. Sending cmt-2nd image (79 kB)... 100% (79 of 0 kB, avg. 79 kB/s) Sending cmt-algo image (507 kB)... 100% (507 of 0 kB, avg. 507 kB/s) Sending cmt-mcusw image (5824 kB)... 100% (5824 of 0 kB, avg. 5824 kB/s) Flashing cmt-mcusw... done. Sending kernel image (1704 kB)... 100% (1704 of 0 kB, avg. 1704 kB/s) Flashing kernel... done. Sending and flashing rootfs image (153344 kB)... 100% (153344 of 0 kB, avg. 153344 kB/s) Finishing flashing... done CMT flashed successfully H:\Program Files\maemo\flasher-3.5> |
How can i unlock my Nokia N900 from T-mobile? | ostego | Nokia Windows & MeaMo/MeeGo based | 0 | 03-29-2010 23:16 |
Solution who have incounter after SD repair Mx-key Contact Service Solve by Cyclone | Code:L.A 22 | Nokia Base Band 5 ( BB-5 ) | 3 | 02-04-2010 16:27 |
mx key nokia 6600 wd2 flashing error ???? | debmobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-02-2010 20:06 |
MX Key, Nokia + Blackberry Unlocker! - Stock for Retail and Wholesale! | NetworkUnlocking | Main Sales Section | 0 | 02-01-2010 21:56 |
