Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 04-20-2010, 14:14   #1 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Cant flash 3110c
Jaf log here
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010)
Processing file: rm237__07.21.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.48 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
Unknown ID !
Error getting boot info !
Bootstrap failed!
Flashing terminated with error(s) in 51.825 s
RX Buffer:
Old 04-20-2010, 14:15   #2 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
ufs log here
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 130001162DEB7C5678795E5B0D89CE5CFA062F8E
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
Storing certificate ...OK
Erase size: 16.37 MB
CMT NOR area [00000000-000006BF] erased in 0.881 s
CMT NOR area [000006C0-0001FFFF] erased in 0.170 s
CMT NOR area [00020000-0007FFFF] erased in 1.022 s
CMT NOR area [00080000-000DFFFF] erased in 0.200 s
CMT NOR area [00100000-001FFFFF] erased in 0.341 s
CMT NOR area [00200000-0031FFFF] erased in 0.350 s
CMT NOR area [00320000-0105FFFF] erased in 3.145 s
CMT NOR area [01060000-01067FFF] erased in 0.160 s
CMT NOR area [01068000-0107FFFF] erased in 0.150 s
Flash programming ...
Error while programming [00] at 0xFFFFFFFF, Result: 0000
Please try to use newer flashloader.
Flashing terminated with error(s) in 43.643 s
RX Buffer: F372
Old 04-20-2010, 14:18   #3 (permalink)
alasmmar's Avatar
Member: 231153
Tick fast flash or flash with ded usb
Old 04-20-2010, 14:21   #4 (permalink)
r4r4's Avatar
Member: 712974
your flash ic is dead....
Old 04-20-2010, 14:34   #5 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
But it also done with jaf box .
WHY ?
Old 04-20-2010, 15:22   #6 (permalink)
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727
Sim-lock Data Corrupted Problem...........
Problem Solve With Mx-key Make Sim-lock rpl Data Update
MCU SW : V 06.60 21-05-08 RM-237 (c) Nokia.
PPM SW : V 06.60 21-05-08 RM-237 (c) Nokia. MEA
Product : Nokia 3110c
Prd.Code: 0544318
Bpr.Code: 0542523
Prod.Sn : MYJ159690
HW Vers : 5005
EM RETU : 32
EM TAHVO: 53
RFIC Ver: 17211721
DSP Vers: ICPR61_08w10
IMEI : 356789-02-906952-1
SL Serv : SIMLOCK SERVER VERSION 63
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland
Old 04-20-2010, 15:24   #7 (permalink)
Rhyan777's Avatar
Member: 893209
WHY ?
Hmmmmmmmmmm....
Maybe your SETTINGS Bro..
UNCHK SAFE FLASH,CHK FAST Flash..
Mine no PROBLEM Bro..
Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010)
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 0BE0010E8B827C56CC6A28FA18473B12C8536095
ASIC MODE ID: 00
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
erased in 1 min 22.219 s
Erase size: 4.62 MB
CMT NOR area [01080000-0151FFFF]
erased in 18.109 s
Erase size: 10.75 MB
CMT NOR area [01520000-01FDFFFF]
erased in 1 min 19.766 s
Erase completed in 3 min 1.000 s
CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written.
Programming completed in 2 min 44.734 s
Flashing completed in 5 min 54.438 s
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35681502196059-7
Product Code: 0552814
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356815021960597
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 6 min 17.656 s
Br,.
Rhyan777
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
Nokia Flash Content. Phantom Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 05-01-2000 23:28
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.31826 seconds with 11 queries
