03-24-2012, 22:30 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Around the Globe
Member: 815786 Status: Offline Thanks Meter: 37 | Can't get any phone in local mode. (ANSWERED) everything starts normal, but when press power on phone it goes directly in "test mode" I am sure it's not cable problem becoz phone boot well with UFS under JAF. Any one got this problem before? how to solve this problem, much appreciation for your help. here is bus check log of any dct phone. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: xxxxxxxxxx Using device: HTI, FW ver: 00.50, SN: 0000xxxx Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012) Boot error: CC CC CC 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Last edited by Joey888; 03-24-2012 at 22:39. |
03-25-2012, 17:13 | #5 (permalink) |
No Life Poster Join Date: Sep 2007 Location: I donot know what is the best Age: 51
Member: 581626 Status: Offline Thanks Meter: 184 | if you have a BB5 device try to choose DCT4 from liste and make scan phone, your BB5 phone will be in local mode, know choose BB5 from liste and make whatever you want |
03-25-2012, 22:09 | #6 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: tunisia elmanar sfax
Member: 636518 Status: Offline Thanks Meter: 175 | Quote:
use ver 1.6 tested 10000/100 | |
03-28-2012, 03:13 | #7 (permalink) |
Member: 815786 Status: Offline Thanks Meter: 37 | ver 1.6 won't boot either. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: C080000 Using device: HTI, FW ver: 00.50, SN: 00000000 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 |
03-29-2012, 23:13 | #9 (permalink) |
Member: 815786 Status: Offline Thanks Meter: 37 | I installed rev 1.9 today and tested different phones: 1208, 1209, 1661. All of them boot fine by UFS using easy cable but HTI. when do "bus check" it stops at "sending boot", here is the log MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: xxxxxxx Using device: HTI, FW ver: 00.50, SN: xxxxxxxxx Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 |
03-30-2012, 07:01 | #10 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
ask for box exchange to your reseller. br | |
