02-06-2010, 18:30 | #1 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 898963 Status: Offline Thanks Meter: 69 | can't repair 7210c rm436 simlock corrupted here is log Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35196203242997-5 Product Code: 0566718 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SECURITY_TEST passed TimeStamp: 2009-07-20T08:46:14Z SW Version: 07.23 Variant Version: 006 ProductProfile: RM436_0566718_07.23_006.spr Simlock: 0566718_simlock.bin SIMLOCK_DATA corrupted! log repair SIMLOCK_DATA corrupted! Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 07.23 17-07-09 RM-436 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.875 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-436_351962032429975_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! pls help thank's advance br: |
02-06-2010, 21:03 | #4 (permalink) |
Junior Member Join Date: Nov 2009 Location: in my j.a.f box Age: 38
Member: 1172368 Status: Offline Thanks Meter: 6 | A final solution to the problem ( "SECURITY_TEST failed!"), A server after you update 1/backup rpl 2/erase flash with erase file 3/flash phone with last flash (updat flash files) 4/reset npc take are the imei phone will be 123....... 5/make repair sd 6/write good pm whith super sd auth 7/ go to the backup rpl and write tow fild only [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0548252 PSN=SAM715419 HWID=6019 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303533393239350000000000 NPC_DATA_2=0000000000000000000000008343E094133FB34 733BA3B00646F72420000000015D00004F86D0254 NPC_DATA_3=993B8A5575DDE33F61271BF75E8D0D504A0902E 261268C14FCD8A2C9093523BC08B29FC2A70A4CF5 NPC_DATA_4=C5D28C7A013690617623EAB7000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3325190632277731FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=527AAD011F00000000000000000000000000000 0000000000000000000000000AEDB09F99D6E0BE4 NPC_DATA_7=34FE5501291C21811678030DA507E6BEB5C747B 51C3344AD9B0BA476149D955EBCBF48C27D7F238B NPC_DATA_8=7E609DF67F0305DA97882F9F54AAA83778C645A 2B3D25508A9881F510782B60B1DC321BE93E767E9 NPC_DATA_9=34BF634260B71733E822679E617CA4318570EC3 BDFC2F3789633B7307432E4D888180B4AEB069C2A VARIANT_DATA_1=357043A5020041500100000030353339323 935430033E093DC71CE448E005600D826990000000000 VARIANT_DATA_2=08000000220000000000000000000000AB9 68C43BFFF7AF7276138E0D251449807EBE517BD6A92CA VARIANT_DATA_3=025FC6132B207237945BC457C122271FCD7 A00EB2119FEAF7A8FCBED4D2C7BCA903DCF8308ED1403 VARIANT_DATA_4=3E2C060B117A0A8F0DE44E1BC878E1152FB 4646F10CE90BF72F7FB95922B3C8FDC261F1C502E1E20 VARIANT_DATA_5=7EB9CCE7541D6B6ACCD98FBC7217F210776 F0366FB887423 the problem will be solved big thank`s manole |
The Following User Says Thank You to Eng_walied For This Useful Post: |
02-10-2010, 08:38 | #6 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Complete repair damaged simlock(except SL3 at moment) and superdongle by mxkey: 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. You got Only NPC? NO PROBLEMO! br, |
The Following 6 Users Say Thank You to Andra For This Useful Post: |
02-10-2010, 08:50 | #7 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Philippines
Member: 42604 Status: Offline Thanks Meter: 187 | I repaired one 7210c with SIMLOCK_DATA corrupted! yesterday by just ticking repair simlock then click update simlock... simple as that... of course i made a full back up of PM and RPL 1st... |
The Following User Says Thank You to kasamiko For This Useful Post: |
02-10-2010, 13:23 | #8 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: Jamalpur, Bangladesh
Member: 623873 Status: Offline Thanks Meter: 41 | Quote:
RX2 Pin not Connected, pls help | |
02-10-2010, 19:08 | #10 (permalink) |
No Life Poster Join Date: Nov 2005 Location: india Age: 47
Member: 196194 Status: Offline Thanks Meter: 47 | Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35318003459147-2 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! simlock repair error SIMLOCK_DATA corrupted! Backup already exist. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 07.23 17-07-09 RM-436 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x11BC bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending KEYS [SL20] (0x19C0 bytes) ...OK Calculating LOCK data ...OK Unlocked PM saved to "C:\mobileEx\3.3\data\backup\353180034591472_UNLOC KED.PM" Writing Unlocked PM ... failed regards! Repair Simlock > Repair SPLock |
02-10-2010, 23:19 | #11 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: iraq
Member: 231662 Status: Offline Sonork: 1607488 Thanks Meter: 390 | Quote:
Dr.Saif (Tc) | |
02-20-2010, 18:16 | #12 (permalink) | |
Member: 898963 Status: Offline Thanks Meter: 69 | Quote:
SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[072002147B247D5625962219AE7A964B622D2599] ... Calculating SIMLOCK using security server ... Completed in 1.485 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-436_351962032429975_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! pls any solution...... br; | |
02-20-2010, 18:19 | #13 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Update SIMLOCK error 1.Backup RPL ( just in case ) 2.erase eeprom 3.Repair SUPERDONGLE and SIMLOCK 4.Factory Default 5.Super SD Auth + PM [1] & [309] 6.post result ps : always use last module update br, |
02-21-2010, 17:59 | #14 (permalink) | |
brSIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[072002147B247D5625962219AE7A964B622D2599] ... Calculating SIMLOCK using security server ... Completed in 1.813 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-436_351962032429975_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! br; | |
02-21-2010, 18:17 | #15 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Indonesia
Member: 90761 Status: Offline Sonork: 1617079 Thanks Meter: 95 | Quote:
i can't repair 5130c-2 SIMLOCK invalid!, SIMLOCK_TEST failed! | mohit_kripalu01 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 19 | 10-10-2010 16:52 |
Another 7210c Repaired [CS with SD and simlock corrupt] | alfox | Universalbox | 1 | 01-16-2010 11:08 |
can i repair 7210c sp area corrupted without rpl? | zone3 | Genie Universal | 11 | 10-24-2009 12:24 |
7210c - rm436 | lahdache | HWK | 2 | 06-24-2009 06:34 |
Nokia 7210C-RM436 Downgrade Problem | maplegsm | Cyclonebox | 4 | 04-20-2009 05:23 |
