Member: 172261
Thanks Meter: 364 | Can't restore imei Quote:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0808080
Using device: USB ROM and HTI, FW ver: 00.50, SN: 00002BBB
Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 0660010A2FFE02520781F153BBD60A239DB60FEA
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS is blank/erased.
Original Imei: 00000000000000
Original Product code:
SIMLOCK PA identifier:
[0] PA_SIM
Reading CMT NPC (0xFF bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0xFF bytes).
Reading CMT HWC (0xFF bytes).
Reading CMT R&D (0xFF bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: 1E5FDA84
Verifying communication to device...
i've backup full PM and RPL
when write PM >> failed
when write RPL >> no NPC data |
