03-19-2010, 22:36 | #9 (permalink) |
No Life Poster Join Date: May 2008 Location: amman
Member: 764174 Status: Offline Thanks Meter: 259 | remove usp cable from phone and battery then press flash then conect usp first then bateery then press power |
The Following User Says Thank You to ahmad yousif For This Useful Post: |
03-19-2010, 22:52 | #11 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Irvinestown
Member: 719399 Status: Offline Thanks Meter: 228 | Quote:
You're great Library version: 1.0.0.7920(18-03-2010), 1.0.0.12662(19-03-2010) Processing file: rm540__04.11.mcusw as MCU [BB5,XSR 1.6] size: 25.92 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 227AD312 RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 07C001065C440E49F9EA73E056C598D3E10D48AB RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Loading CMT secondary boot code SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.48.0 revision: 2.1 size: 0x3BC0 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 2.1 size: 0x7E232 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Update Server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 227AD312 [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E Storing certificate OK. Partitioning.... Partitioning complete Erase size: 37.69 MB Flash programming ... CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500626C6F (RAP Certificate 193 v.1) written. Programming completed in 31.234 s Processing file: rm540__04.11.ppm_b as PPM [BB5,XSR 1.6] size: 6.47 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 8.87 MB Flash programming ... Programming completed in 7.719 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia USB Generic, ID: 143A5FF5 [ADL] Verifying communication to device OK. Flashing completed in 1 min 19.328 s Phone Type: RM-540 (Nokia X3-00) SW Version: V 04.11 09-12-09 RM-540 (c) Nokia Imei plain: 35936703740785-5 Product Code: 0593371 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359367037407855 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 1 min 22.359 s | |
[MXKEY - INFO] MXKEY CCS Tools Manual | Andra | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 62 | 12-21-2010 08:38 |
CCS Tool could not connect to Nokia ODM 2505 | teknisi bloon | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-25-2010 16:16 |
nokia 1255 ccs tool not working????? | omkarvitekar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-02-2010 17:57 |
ccs tool plzzzzzz | solanki telecom | Nokia CDMA | 0 | 02-03-2010 16:29 |
1255 in dm mode but not detected on the ccs tool | sanjubhai | Nokia CDMA | 3 | 05-25-2009 10:59 |
