06-11-2011, 11:45 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: pakistan
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | check this seniors? SW Version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35417903752056-0 Product Code: 0581455 Battery voltage: 4778 mV, current: 69 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3541790375+++++ Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN is it safe repairable with mxkey(avoid cs after sd repair)???? if tested sombody,,,then post...... |
06-11-2011, 12:06 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | if u make backup rpl in all section then why tension? do backup rpl in all section. after repair sd phone goes to security test fail and u know how to repair security test fail. BR |
06-11-2011, 19:02 | #5 (permalink) |
Freak Poster Join Date: Sep 2008 Location: At the center of the Earth
Member: 851708 Status: Offline Sonork: 1000.2brian Thanks Meter: 15 | mx key repair this problem more than a year ago! i tested too on many sets. if you have doubts search in forum, and by the way this is the easiest problem to repair. |
The Following User Says Thank You to muthoka For This Useful Post: |
06-11-2011, 19:10 | #6 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Makum, Assam, India
Member: 1540165 Status: Offline Sonork: 100.1606502 Thanks Meter: 29 | Quote:
Brother, Repair SD without any doubt. Your IMEI plan is valid, So no tenssion. IF you feel lack of confidence then backup all rpl before operation. I have no logs to post but succed in many times Last edited by KKBaruah; 06-11-2011 at 19:16. | |
06-11-2011, 19:35 | #8 (permalink) |
Member: 851708 Status: Offline Sonork: 1000.2brian Thanks Meter: 15 | is it safe repairable with mxkey(avoid cs after sd repair)???? if tested sombody,,,then post......[/QUOTE] boss after sd repair, the set will go into CONTACT SERVICE which tou seem to be afraid of. this is due to security test failed! to repaier that you neeed to do sx4 and write pm 1 and309. if you need evidence look at this http://forum.gsmhosting.com/vbb/f550...wered-1154996/ |
New to all this (about 1 hour) :) | Mark UK | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-01-2010 09:01 |
check out my FREE large gsm soft site | LaLGsm | GSM Mobile Links | 0 | 01-16-2001 04:36 |
try this for nokia 5.36 | BELY | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-28-2000 00:59 |
READ this IGOR_M!!!!!!!!!!!!! | nightxyz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-04-2000 04:49 |
Has someome tested this software Nokia New Series Tool? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-20-2000 16:39 |
