Old 10-04-2012, 15:13   #1 (permalink)
Member: 430612
Thanks Meter: 301
x2-01 dead flash with c3-00 files
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0858A46
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 00007BDC
Connection status: EHCI:HUB:HUB:USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Processing MCU file: rm709__08.71.mcusw
[BB5,XSR 1.6] size: 26.61 MB
Supported Ids: 2200050920030000, 22000509200C0000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 000000000080834C6B3B0DDFCFD0EE77B103B184
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH:
1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1D5A26EF
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35861504574395_CE RT.rpl).
CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 33.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT ADA block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 37955B6F [] sent
CMT UPDAPP block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 13.375 s
Processing PPM file: rm709__08.71.ppm_mh1
[BB5,XSR 1.6] size: 6.53 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
Programming completed in 2.922 s
Processing CNT file: rm709__08.71.image_mh1_059D7F8
[BB5,XSR 1.6] size: 23.91 MB
Erase size: 75.31 MB
CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
Programming completed in 11.250 s
Total time for flashing process(boot+erase+write) was 38.250 s
Waiting for USB device arrival ...OK
Waiting for device boot up ...
Old 10-04-2012, 16:34   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Easy to recover if Backup RPL,
If so then follow Erase from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ ,
After Erase Flash it with latest Firmware with same Product Code,
Restore Backup RPL & Post reply.
BR,
ZUBER
The Following 2 Users Say Thank You to .::ZUBER::. For This Useful Post:
Page generated in 0.14594 seconds with 8 queries
