06-19-2011, 07:51 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Balochistan
Member: 952072 Status: Offline Sonork: 100.159775 Thanks Meter: 107 | Checksum mismatch: Phone calculated 0x1513, software calculated 0xB5CB Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: USBUHCI:UFS2XX, ver: 2.0.0.0 , NTMP ver: 2.0.0.1 Module ver: 1.0.0.17626(14-06-2011), Library ver: 1.0.0.11296(14-06-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 0020 08C0 [ST ] Processing file: rh125_004.650 Downloading item CODE:hw_f11_rh125_r04.650.fls, num block: 3, size: 4.08 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 44.890 s Erasing area 0x00C60000-0x00E6407E ...OK Programming completed in 44.281 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.156 s Checksum mismatch: Phone calculated 0xCA2C, software calculated 0x1FF2 Processing file: rh125_004.65ia Downloading item CUST:hw_f11_rh125_004.65ia.fls, num block: 1, size: 1.98 MB Erasing area 0x00210000-0x0040AA3E ...OK Programming completed in 41.656 s Checksum mismatch: Phone calculated 0x4C78, software calculated 0x0EE0 Processing file: rh1250_nai04.65ia Downloading item CUST:hw_f11_rh1250_nai04.65ia.fls, num block: 1, size: 351.70 KB Erasing area 0x00EB0000-0x00F071BE ...OK Programming completed in 7.375 s Checksum mismatch: Phone calculated 0x1513, software calculated 0xB5CB Total time for flashing process(boot+erase+write) was 4 min 4.703 s Phone not responding ! |
The Following User Says Thank You to Karim Noorzai For This Useful Post: |
06-19-2011, 10:28 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | YES ME TOO FACED THIS PROBLEM TODAY NOKIA 1800 RM-653 Code: Backup saved to C:\mobileEx\3.5\data\backup\XGOLD_RM-653_54CAFE9227A0BD2F_IMEI.back MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 5] - C0000000 Using device: HTI BOX, FW ver: 00.17 Driver: USBOHCI:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17626(14-06-2011), Library ver: 1.0.0.11296(14-06-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing file: rm653_006.200 Downloading item CODE:hw_b2_rm653_r06.200.fls, num block: 3, size: 4.11 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 46.031 s Erasing area 0x00C60000-0x00E6A0BE ...OK Programming completed in 44.063 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.156 s Error reading checksum! Processing file: rm653_006.20qb Downloading item CUST:hw_b2_rm653_006.20qb.fls, num block: 1, size: 1.88 MB Erasing area 0x00210000-0x003F12FE ...OK Programming completed in 38.750 s Checksum mismatch: Phone calculated 0x0040, software calculated 0x91F9 Processing file: rm6530_nai06.20qb Downloading item CUST:hw_b2_rm6530_nai06.20qb.fls, num block: 1, size: 333.20 KB Erasing area 0x00EB0000-0x00F027BE ...OK Programming completed in 6.781 s Checksum mismatch: Phone calculated 0x00F1, software calculated 0xE104 Total time for flashing process(boot+erase+write) was 3 min 52.531 s Phone Type: RM-653 SW Version: V 06.20 01-12-10 RM-653 (c) Nokia Imei plain: 35154404618079-2 Product Code: 0594703 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: QB Language Pack: English,Chinese S,Bahasa Mal Imei net: 35154404618079 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN PLS CHECK THIS MX-KEY TEAM WBR sahil2000ind |
