02-03-2010, 14:23 | #1 (permalink) |
Junior Member Join Date: Oct 2008
Member: 879814 Status: Offline Thanks Meter: 7 | dct 4 working in 3.3. 1.4 Library version: 1.0.0.11985, Date: 03-02-2010 ASIC ID: 0x3160 [UPP_8M ver: 6.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0047C32B:2984DA60 ASIC type: 2 UEM Imei: 35294002253149 Flash Imei: 35294002253149 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35294002253149_BA CK.rpl" Processing file: rm166__04.220 as MCU [DCT4,DCT4 ALGORITHM] size: 8.72 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 3161, 3160 ASIC ID: 0x3160 [UPP_8M ver: 6.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0047C32B:F4E0DA60 Area [01000000-0101FFFF] erased in 1.078 s Area [01020000-018DFFFF] erased in 1 min 18.000 s Area [01E60000-01FDFFFF] erased in 13.640 s Flash programming ... Programming completed in 1 min 13.172 s File Processed in 3 min 0.985 s Processing file: rm166__04.22.image_w_ctv_india as CNT [DCT4,DCT4 ALGORITHM] page size: 64 K size: 1.63 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 3161, 3160 ASIC ID: 0x3160 [UPP_8M ver: 6.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0047C32B:0BDFDA6A Area [01B20000-01E5FFFF] erased in 29.547 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 15.625 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.078 s File Processed in 1 min 15.765 s Processing file: rm166__04.22w as PPM [DCT4,DCT4 ALGORITHM] size: 1.97 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 3161, 3160 ASIC ID: 0x3160 [UPP_8M ver: 6.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0047C32B:2984DA60 Area [018E0000-01B1FFFF] erased in 20.047 s Flash programming ... Programming completed in 15.625 s File Processed in 48.860 s Flashing completed in 5 min 28.546 s After Flash Processing ... Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. Updating SIMLOCK ...OK Phone Type: RM-166 (Nokia 6070) SW Version: V 04.22 24-05-07 RM-166 (c) Nokia. Imei plain: 35294002253149-6 Imei OTP: 35294002253149 Product Code: 0534580 Cellular System: GSM ASIC ID: 0x3160, type: 2 Ppm Id: W Language Pack: English,Chinese S,Chinese T,Hindi,Bahasa Ind Imei net: 35294002253149 Version: SIMLOCK SERVER VERSION 58 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 5 min 49.843 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 12.031 s |
mxkey setup ver 3.3 rev 1.4 fast link (answered) | obioha | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 10-31-2010 20:58 |
6120c after unlock by mxkey 3.3 rev. 1.4 auto shot off in 20mins | kristine dawn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 07-15-2010 04:41 |
blackrain not working in 3gs 3.1 | kapilgupta | iPhone 2 / iPhone 3G / iPhone 3GS | 15 | 02-24-2010 12:16 |
xGPS Not working in Version 3.0 | ehd0429 | iOS Application, games & media area | 2 | 01-16-2010 07:38 |
Moto Codes 1-4 Hrs, 3 UK 1-4 Days, Voda UK, T-Mobile UK/USA 24 Hrs Rogers Instant! | yasin_shafi | Main Sales Section | 0 | 05-03-2008 17:14 |
