07-28-2010, 03:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | dct4 imei repair help! [HARDWARE PROBLEM] 1st log ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2227 [Samsung K8S3215ETD,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0054F6F0:2984DA60 ASIC type: 2 UEM Imei: 35623200937377 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35623200937377.RP L" ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2227 [Samsung K8S3215ETD,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0054F6F0:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Programming UEM Imei (OTP) ...failed Phone Type: RH-18 SW Version: V 8.11 19-06-06 RH-18 (c) NMP 1100 Imei plain: 35623200937377-9 Product Code: 0513376 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: EJ Language Pack: - not available. Imei net: 35623200937377 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN 2nd log for 1600 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 001B1C5C:2984DA60 ASIC type: 2 UEM Imei: 35326501973130 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35326501973130.RP L" ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 001B1C5C:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Programming UEM Imei (OTP) ...failed Phone not responding ! |
The Following User Says Thank You to tonywireless For This Useful Post: |
07-28-2010, 03:48 | #2 (permalink) | |
Banned Join Date: Sep 2007
Member: 583468 Status: Offline Sonork: 100.1592004 Thanks Meter: 106 | Quote:
1. choose genaration dct4 2. service, IMEI & Security 3. Online Loger 4. Click Login after tht click button Calculate Manual 5. Then put ur IMEI and ASCI Type and click on request rpl 6. Then Write rpl manualy.. Hope u getur mobile workd...... | |
The Following 3 Users Say Thank You to jmzboudh For This Useful Post: |
08-01-2010, 12:43 | #5 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | thanks all for ur replies i have been able to write the rpl suceesfully,the imei does not show question mark again but now the phone powers on and goes off while operating it in less than 1 mins have changed battery written pm and flashed the phone (2300)with the highest version still the same thing what do i do now pls |
08-09-2010, 03:49 | #8 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | pls what do u mean by change uem explain better cos i am still searching for a solution to the tripping off (after writing the rpl successfully and the phone is no longer showing question mark) problem pls somebody help Last edited by tonywireless; 08-09-2010 at 03:56. |
