01-28-2011, 08:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | DCT4 New UEM RPL Failed we change the uem of this phone it is a new and working uem,but when we try to write OTP UEM rpl it always be Blanked,no programming of Blank new uem. Code: ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 005A4F62:DA3BDA66 ASIC type: 11 UEM Imei: Empty ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 005A4F62:DA3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ... UEM programmed successfully. Phone Type: RH-105 SW Version: V 6.00 30-09-09 RH-105 (c) NMP Imei plain: ??????????????-? Product Code: 0546862 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! always error while automatic uploading rpl file to phone Code: FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 005A4F62:DA3BDA66 ASIC type: 11 UEM Imei: Empty SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.5 |
01-28-2011, 08:22 | #2 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: india
Member: 731839 Status: Offline Thanks Meter: 45 | Quote:
01-28-2011, 08:45 | #3 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | @jafarH , be please to clarifie ? when we fix new uem is it better to calcute rpl by manual method? is mx key does not calculate flash imei for new rpl in online logger post more details please. thanks advanced NEIL |
01-28-2011, 09:06 | #4 (permalink) |
Member: 731839 Status: Offline Thanks Meter: 45 | chake the "calculate manual" after login in loger write manuly imei no withe key bord, slect Asic type 2,5,7, or 11 must slect correct asic type, then click requst rpl, after calculate write the rpl file manualy with write rpl option one " imei rebuit " tabe NOTE- be cearful because new(empty) UM can program only one time |
01-28-2011, 10:51 | #5 (permalink) | |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
