dct4 rpl server down plz chek this ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C4C503:2984DA60 ASIC type: 2 UEM Imei: 3153********* Connecting to server ...OK, Login ... Hello xxxxxxx, you have **** credits left. Invalid DATA1 length, expected: 80 chars. |
Use jaf interface......................................... .ok ak' |
Already try with jaf & ufs interface but same bro........ |
i got like this but try later 2 time its done. |
no the server is ok...... Connecting to server ...OK, Login ... Access granted using virtual credit Hello C0******, you have 1 credits left. Connecting to server ...OK, Login ... Access granted using virtual credit Hello C0******, you have 1 credits left. RPL saved to "F:\mobileEx\3.3\data\backup\RPL\35336000306284.RP L" |
NOW PROBLEM SOLVED. ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C4C503:2984DA60 ASIC type: 2 UEM Imei: 31536700100386 Connecting to server ...OK, Login ... Hello *********, you have **** credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\3153670*****. RPL" ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C4C503:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-9 (Nokia 3510i) SW Version: V 05.35 17-08-04 RH-9 (c) NMP. Imei plain: 31**********86-5 Imei OTP: 31536700100386 Product Code: 0509430 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: G Language Pack: English,French,German,Spanish,Arabic Imei net: 31********386 Version: SIMLOCKLIB VERSION 2.26 Counter: 0/3, 0/10 CONFIG_DATA: 5269402D9E133424 PROFILE_BITS: 7C46364463DA9920 |
