09-23-2013, 08:48 | #1 (permalink) |
Freak Poster Join Date: Apr 2004
Member: 63177 Status: Offline Thanks Meter: 15 | Dead Asha 302 after log read ERROR: Loader not responding ! Phone is new!!! Some help maybe ? |
09-23-2013, 10:40 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. May be something went wrong while trying to read Logs, Contact Nokia Service Center if in Warranty. BR, ZUBER |
09-23-2013, 11:27 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | @zuber HOW CAN SOME THING CAN GO WRONG IN READING LOGS? CAN U EXPLAIN MORE I HAVE SEEN MANY USER HAVING PROBLEM WITH ASHA PHONES EVEN I TOO HAVE FACED PROBLEM IN FLASHING AND UNLOCKING ASHA PHONE THATS THE BUG IN MX-KEY SOFTWARE. @hoze!!! PLS TRY TO FLASH URE PHONE WITH SAME PRODUCT CODE AGAIN WITH MX-KEY OR SOME OTHER NOKIA FLASHER IF U HAVE ALSO PLS POST RESULTS I HAVE SEENS SOME MEMBERS THAT FACED PROBLEM WITH ASHA PHONE IN MX-KEY SOLVED THEIR PROBLEM WITH OTHER NOKIA FLASHERS ALSO PLS MAKE SURE U HAVE FULLY CHARGED BATTERY WBR sahil2000ind |
09-23-2013, 11:28 | #5 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
There is safer way, You have to Synchronize File for minor Update, Bugs fixed for reading Asha Series & some other Phones, But now don't try to flash it with software & contact Nokia Service or else will not resolve your problem. BR, ZUBER | |
09-23-2013, 15:47 | #9 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | SL LOGGER WILL NOT DESTROY SIMLOCK JUST FLASH IT AGAIN WITH CORRECT RM AND PRODUCT CODE AND URE PHONE WILL BE OK ALSO PLS POST FULL BUSCHECK AND FLASHING LOGS FOR COMPLETE ASSISTANCE WBR sahil2000ind |
09-24-2013, 16:15 | #12 (permalink) |
Member: 63177 Status: Offline Thanks Meter: 15 | Total time for flashing process(boot+erase+write) was 36.781 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia Asha 302 USB Phonet, PORT_ID: 35633505xxxxxx Verifying communication to device OK. Phone type: RM-813 (Nokia 302) SW version: V 14.92 09-11-12 RM-813 (c) Nokia Imei plain: 35633505xxxxx-x Battery voltage: 3855 mV, current: 159 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: 0C219803XXXXXX, ver: SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
09-24-2013, 16:19 | #13 (permalink) |
Member: 63177 Status: Offline Thanks Meter: 15 | bus check MXKEY [MxKey Team HTI PLUS Flasher Interface 7], SN: xxxxx Using device: USB Phonet and HTI, FW ver: 00.50, SN: xxxxx Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.115 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: AC5E0000FFFB7C4085CD80AF8A21C8F930B1F232 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 400C192103042108, 0003192103042108, 4003192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0131 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0131 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD45E0 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 400C192103042108, 0003192103042108, 4003192103042108 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2118965 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Selected firmware certificate matched. Original Imei: 35633505xxxxxx Original Product code: 059P462 Bluetooth ID: F4F5A5EF949D SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1E8 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia Asha 302 USB Phonet, PORT_ID: 356335058xxxxxxx Verifying communication to device OK. Phone type: RM-813 (Nokia 302) SW version: V 14.92 09-11-12 RM-813 (c) Nokia Imei plain: 35633505xxxxxx-x Battery voltage: 3853 mV, current: 159 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: 0C219803XXXXXX, ver: RPL saved to "D:\mobileEx\3.5\data\backup\BB5_RM-813_35633505xxxxxxx_24_09_13_171743_SIM.RPL" SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
12-04-2013, 16:21 | #15 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2077006 Status: Offline Thanks Meter: 0 | nokia asha 302 hello sir . what if my nokia asha 302 is dead boot but still function of all programs, but i restore all settings then it happen again! do you think i need to flash it ? what box i need ! . . . newbie in this site can you please help me !! thanks |
