07-19-2012, 15:30 | #1 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: Wish Phone
Member: 331835 Status: Offline Thanks Meter: 64 | Downgrade C5-03 RM-719 Failed how to make this phone to local mode again and back to normal again i have backup full RPL and full PM this phone ...but i can not write full rpl because phone is not going to local mode and test mode try to erase using file by gbluez ini here : http://forum.gsmhosting.com/vbb/f550...ml#post8233274 but phone still not local mode or test mode..and now the phone still alive but imei : 12345654321? and the phone going to watchdog here is log flashing : Quote:
07-19-2012, 15:40 | #2 (permalink) |
Freak Poster Join Date: Feb 2011
Member: 1522958 Status: Offline Thanks Meter: 24 | Do full erase on mxkey, then flash phone with original product code,write full rpl, go to mei&securty tab >imei rebuild>repair sd.Go to pm tab click sd auth writ full pm and for desert full factory. good luck |
The Following User Says Thank You to kamertonas For This Useful Post: |
07-19-2012, 22:48 | #3 (permalink) | |
Member: 331835 Status: Offline Thanks Meter: 64 | Quote:
i have to do full erase using erase file from mr gbluez,but phone still not going to local mode | |
07-20-2012, 02:09 | #4 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Yogyakarta, ID
Member: 1786327 Status: Offline Sonork: 100.1621394 Thanks Meter: 58 | As gbluez said, that erase file is very nasty... use with caution. Also you have done CROSS RM, make sure firmware is MATCHED as sticky post here: http://forum.gsmhosting.com/vbb/f550...-post-1267078/ Now you can erase again, and TRY put it to the INITIAL condition. YePe |
The Following User Says Thank You to yogyaphone. For This Useful Post: |
07-20-2012, 03:47 | #5 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
If you can manage this condition on "USB Phonet" as interface, just restore IMEI after phone scanned. Make sure you're cross RM CORRECTLY. Or, put it back to the first state, as YP said. BR | |
The Following User Says Thank You to gbluez For This Useful Post: |
07-20-2012, 09:27 | #6 (permalink) | ||
ignore local or test mode and try to restore imei,phone was not alived..only nokia startup and blank try to erase again with erase file from gbluez..adn then flashing again..phone come to life again ,but imei : 12345654321? ,phone was going to watchdog again maybe mr gbluez can help me to make "erase file" for my phone ...thank's for your kindness | ||
07-21-2012, 10:17 | #8 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Don't know where you massed up, anyway will try to recover again, follow step by step if Backup already present. 1st. Select Nasty Uni.BB5_Erase file which you already downloaded, put in MCU & tick with keeping other file tabs untick. 2nd. Click Flash will Erase whole Flash Chip. 3rd. Download Lowest Firmware with same Product Code of your Phone. Which must be RM-719 Ver 11.1.24 or Ver 12.0.23 depend on Product Code. 4th. Flash it with the above Match Firmware. Now i think will enter Local & Test Mode. 5th. Anyway write Backup PM will show IMEI-12345........? with Simlock Invalid. 6th. Click Restore IMEI, if getting error for Restore, then write RPL Manually will solve everything. 7th. If everything OK, just Flash with Latest Firmware of same Product Code of your Phone. 8th. Without changing RM of Phone, return to Customer with Thanks. Best Regards, Zuber Chowdhry |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
07-21-2012, 15:09 | #9 (permalink) | |
as i know ,if phone is not going to local mode or test mode , it can't be to restore imei and simlock i am so confused..maybe i must wait new update of firmware from nokia but it's so long ........hmmmmmmmmm | |
07-22-2012, 10:46 | #10 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
its so great to see u still with us, sir @willydewi i have never known that downgrading can use different rm file. i have 1 question: what rm u choose while u erasing the phone? br Sent from my iPhone using Tapatalk | |
The Following User Says Thank You to specta For This Useful Post: |
07-22-2012, 11:16 | #12 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Use RM-719 while Erasing to make it appears in Local & Test Mode, Reason is RM-697 Firmware which you using must be Mismatch with yours Original Product. All Latest SL3 Series gets this problem of Mismatch Firmware. BR, Zuber |
07-22-2012, 22:53 | #13 (permalink) | |
i am so confused now ..i don't know what can i do to repair this phone? i hope someone can make "full erase file" for this type | |
07-23-2012, 03:31 | #14 (permalink) |
No Life Poster Join Date: Jan 2011 Location: HARDOI (U.P.) INDIA Age: 36
Member: 1483881 Status: Offline Sonork: 100.1612698 Thanks Meter: 93 | brother first of all just flash with same product code flash file ..... and go to service - quick fixed - tick bb5 downgrade fixed . and press do jobs and after doing this your phone willbe able to go test mde write pm and rpl................ and post results |
The Following User Says Thank You to samo_d1 For This Useful Post: |
MCU EEPROM contents: failed | phr3ak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-12-2001 15:58 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
