Old 03-03-2010, 20:16   #1 (permalink)
Member: 219015
Thanks Meter: 42
3510i rh-9 can't repair IMEI
I can't repair imei, I calculate RPL with MXKey server and write but it don't repaired...
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
Performing Flash Authentication ...OK
UEM ID: 005CEE04:2984DA60
ASIC type: 2
UEM Imei: 35434700973749
Flash Imei: 35434700973749
MasterCode: 6243431310
RPL saved to "C:\mobileEx\3.3\data\backup\35434700973749_126763 6171_BACK.rpl"
Phone Type: RH-9 (Nokia 3510i)
SW Version: V 05.30 19-03-04 RH-9 (c) NMP.
Imei plain: ??????????????-?
Imei OTP: 35434700973749
Product Code: 0509601
Cellular System: GSM
ASIC ID: 0x1120, type: 2
Ppm Id: E
Language Pack:
English,German,Lithuanian,Latvian,Russian,Estonian ,Bulgarian,Romanian
Imei plain is invalid !!!
Imei net: FFFFFFFFFFFFFF
Version: SIMLOCKLIB VERSION 2.26
Counter: 0/3, 0/10
CONFIG_DATA: 5555555555555555
PROFILE_BITS: 0000000000000000
SIMLOCK_DATA corrupted!
after write rpl...
Programming FLASH Imei ...
FLASH programmed successfully.
Programming UEM Imei (OTP) ...failed
Operation done with error.
this after Init simlock... (in simlock tab)
Counter: 0/3, 0/10
Imei net is empty, process aborted.
How I can repair?
Old 03-03-2010, 21:03   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
DCT4 > Service > Imei& Security > Online Logger.
Old 03-04-2010, 05:30   #3 (permalink)
Member: 219015
Thanks Meter: 42
This after: DCT4 > Service > Imei& Security > Online Logger>with ticked DCT4 IMEI+PRODUCT DATA...
ASIC type: 2
Connecting to server ...OK, Login ...
Hello C0809714, you have 1960 credits left.
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35434700973749.RP L"
Ppm Id: E
Language Pack:
Counter: 0/3, 0/10
and this after: DCT4 > Service > Imei& Security > Online Logger>with ticked DCT4 IMEI...
ASIC type: 2
Ppm Id: E
Language Pack:
Counter: 0/3, 0/10
But can't repair.
How I can repair "Imei net: FFFFFFFFFFFFFF" and "CONFIG_DATA: 5555555555555555"?
Old 03-04-2010, 05:34   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
1. reset data1
2. full erase (get addr, untick safe erase)
3. full flash
4. Online Logger>with ticked DCT4 IMEI
5. if all above succeded, continue write pm, update simlock
Old 03-04-2010, 18:26   #5 (permalink)
Member: 219015
Thanks Meter: 42
1. reset data1
3. full flash
after online logger...
ASIC type: 2
Programming FLASH Imei ...failed
Product Code: 0
Ppm Id: E
Language Pack:
Counter: 0/3, 0/10
I retry online logger and all is OK, but imei plan don't repaired
ASIC type: 2
Product Code: 0
Ppm Id: E
Language Pack:
Counter: 0/3, 0/10
Old 03-04-2010, 18:53   #6 (permalink)
Member: 219015
Thanks Meter: 42
PM write is OK, but I can't update simlock data
Counter: 0/3, 0/10
03.12.2009 New Chinese cocktail v.9.5 repair IMEI in INDIA GSMtricks Multi-box LITE 10 03-08-2012 20:54
03.12.2009 New Chinese cocktail v.9.5 repair IMEI in INDIA GSMtricks Multi-Box 34 02-21-2011 20:38
03.12.2009 New Chinese cocktail v.9.5 repair IMEI in INDIA GSMtricks Service Products News & Updates 0 12-03-2009 18:18
need 3510i RH-9 flash files ifisab Twisterflasher 1 08-03-2005 11:26
Page generated in 0.21598 seconds with 9 queries
