02-19-2010, 11:54 | #1 (permalink) | ||
Freak Poster Join Date: Nov 2009
Member: 1170910 Status: Offline Thanks Meter: 76 | E50 not accepting RPL Backup MX-Key TEam Help[SOLVED] Phone came to me for a upgradation, while flashing in between i got the error Error BSI/RX2 .......... than i flash this phone in JAF it flashed perfectly (Now this is whose problem Mx-Key or Cable, because same cable worked in JAF.) After that i tried to restore my backed up rpl and its not accepting can you telll me why ? here is the log file Scan Log with 1234.... imei Quote:
Please do the need full | ||
02-19-2010, 12:01 | #2 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
02-19-2010, 15:29 | #6 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 618626 Status: Offline Sonork: 100.1592779 Thanks Meter: 61 | Bro Full Erase Your Phone.............. Flash With The Same Product Code On The Back Of Your Phone............ Than Try Restoring Rpl Again.............. Repair Sd.............. Make Super Sd Auth And Write Modified P.m............... Note: If Problem Still Remains For Sure Your Rpl Back Up Is Not Valid........... |
02-19-2010, 15:48 | #8 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | full erase phone flash with same product code (back on phone sticker) restore rpl make simlock repair make sd repair and write pm with super sd auth post result |
02-19-2010, 16:10 | #10 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1009679 Status: Offline Thanks Meter: 166 | hope it's ok to give link complete procedure http://www.tapgsm.com.ph/showthread....&highlight=E50 or 1. After all back-up, do this open Mxkey go Advance, get Address, uncheck eeprom and tick Erase. 2. Now Flash it with E50-2 or RM-171 not E50-1 or RM-170 this is to have a Restored IMEI DATA not 123456? after this is the result. if you scan it's in RM-170 but log shows RM-171 (why we flash with RM-171? since i personally tried all tricks with restore imei and write PM but no success, only this way will restore in Mxkey tool) (Now flash with E50-1 or RM-170 and tick Downgrade check this. check flashfiles i used also. without sim this version will work but with simcard this version is stupid!) 3. so best is use this lower version....tested working! check log SW Version. DL in JAf server RM170p_06271.C01 RM170p_06271.L31 RM170_APAC2.U03 4. then Fullfactory and format this time phone is perfectly working!!! hope this can help you....ENJOY! pls post feedback if success since this solution is tested |
02-19-2010, 18:22 | #11 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | there is something wrong with red fields [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0557631 PSN=SHG437010 HWID=4120 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303535303830354300000000 NPC_DATA_2=0000000000000000000000009143E09402C8614 761A42B00646F7242000000000B500109E8740058 NPC_DATA_3=C150CCB77307A23628480A369C5EA53A1F6DBD7 DF955715E780159991B4B6EA42F631E8EC0E2B55A NPC_DATA_4=F3D1C1126720E9DA99B2D575000000000000000 000000000000000000400000047534D0000000000 NPC_DATA_5=3365890361729655FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=1F88F49A1C00000000000000000000000000000 0000000000000000000000000574C414E5F494400 NPC_DATA_7=EF9309D41C00000000000000000000000000000 0000000000000000000000000434F4D5F53430000 NPC_DATA_8=5E6A81E61E2D6CBD5471777F84DCDC43F321409 8811F7D5B1DC3A4C5CD13873C880671913638D4D6 NPC_DATA_9=C0DC0108ADD462C1886880D25D69D6DF40C2466 6FC15542C335C3687000C65CAB253884BC7BF50E9 NPC_DATA_10=2C5B6F375C9E39CE29D7DFD5D6C7D916E3925F 340048216C61100538A1BA18B15542F7A58580746B NPC_DATA_11=90E6F0BFD61693A41EFEF2F56E63C461E6A46B 496384363C86816E8542950A3C2241E35781EACBF5 checksum=-1 just remove red field and only write NPC field like this [CERT_PROG_DATA_OUT_CMT] NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303535303830354300000000 NPC_DATA_2=0000000000000000000000009143E09402C8614 761A42B00646F7242000000000B500109E8740058 NPC_DATA_3=C150CCB77307A23628480A369C5EA53A1F6DBD7 DF955715E780159991B4B6EA42F631E8EC0E2B55A NPC_DATA_4=F3D1C1126720E9DA99B2D575000000000000000 000000000000000000400000047534D0000000000 NPC_DATA_5=3365890361729655FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=1F88F49A1C00000000000000000000000000000 0000000000000000000000000574C414E5F494400 NPC_DATA_7=EF9309D41C00000000000000000000000000000 0000000000000000000000000434F4D5F53430000 NPC_DATA_8=5E6A81E61E2D6CBD5471777F84DCDC43F321409 8811F7D5B1DC3A4C5CD13873C880671913638D4D6 NPC_DATA_9=C0DC0108ADD462C1886880D25D69D6DF40C2466 6FC15542C335C3687000C65CAB253884BC7BF50E9 NPC_DATA_10=2C5B6F375C9E39CE29D7DFD5D6C7D916E3925F 340048216C61100538A1BA18B15542F7A58580746B NPC_DATA_11=90E6F0BFD61693A41EFEF2F56E63C461E6A46B 496384363C86816E8542950A3C2241E35781EACBF5 checksum=-1 check this process and post result |
02-19-2010, 19:11 | #12 (permalink) |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | Hi, Please do 'BUS Check' then see if 'Original Imei' is not empty, it means that write RPL procedure is OK. If Original Imei is OK, but Imei plain reseted(12345...) it means phones have a bad firmware. Best way to restorethe original fw is do 'Image DL' based by 'Original Product code' which is also shown when doing Bus check. And thats it. BR. ALIM |
The Following 2 Users Say Thank You to Alim Hape For This Useful Post: |
02-20-2010, 16:26 | #14 (permalink) | ||
Member: 1170910 Status: Offline Thanks Meter: 76 | Thanks bro alim problem solved just updating with Product Code thanks for MX-Key here is the log file Quote:
mx key team help me how to get log txt of mx key | sanjayvikas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 01-22-2010 12:48 |
help me plz uesr and passeword!!!!!!!!!!! MX-KEY TEAM HELP | >>the boos<< | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 01-16-2010 17:17 |
mx key team help om this error.. | stacey-ann | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 11-03-2009 08:35 |
MX-KEY team help all users plzzzzzzzzzzzz | rana_jee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 11-02-2009 13:34 |
mx key team help me | shama | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 08-09-2009 13:39 |
