Old 03-05-2010, 01:32   #1 (permalink)
Member: 862105
Thanks Meter: 6
problem with my mxkey pls help
hi support,
i just got my new mxkey, fully installed but every time i open up the software this message pop up "Obselete USB device driver or may not installed properly. You want to automatically reinstall the drivers?" doesnt matter if i press yes or no it will direct me to the file under your mxkey folder and i select 2.4.16.0UFS2xx then it ask if i want to reboot so i reboot then restart the software but the same message pop up again, also i try to install the driver when this message pop up directly from my sarasoft ufs usb driver folder and this will not solve the problem too.
if i press no to reboot the computer this error pop up in your software
"unexpected error: Access violation at address 100840C0. Read of address FFFFFFFC"
pls advice what need to be install to solve this problem and i know if im not install this driver properly i cant use the ufs interface however at this moment i can use jaf interface with all the application without any problem, thanks in advance!
Old 03-05-2010, 09:04   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
your need checkup your PC healty
how about reinstall windows first ?
br,
Big problem with my MXKEY SOS ??? petit1959 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-28-2010 21:11
problem with my mxkey plz help.... khalidjan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 12-17-2009 04:12
Problem with MMC card ... pls help ... alianu x1x to x45/x50 9 06-08-2003 13:09
Page generated in 0.10552 seconds with 9 queries
