01-21-2013, 19:14 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ghana
Member: 943232 Status: Offline Sonork: 1616616 Thanks Meter: 19 | e52-1 any solution Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0000572E Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Battery voltage: 4788 mV Phone type: RM-469 (Nokia E52-1) Product code: 0583919 SW version: 091.004 LanguagePkg version: 091.004091.004.02.01091.004.C00.01 Waiting for USB device removal ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 2420021828660344C40C18B09B492D11957F73D9 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID: 3E273BF637BE26FA Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 190B292B FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Imei: 35521603853354 NPC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35521603853354_NP C.rpl" Erasing CMT NPC ... OK Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 190B292B Waiting for USB device removal ... Device connected: nmwcdc\Nokia E52 USB Phonet, PORT_ID: 1A8D8D90 Verifying communication to device OK. Applying BB5 SW Downgrade patch ... Reading signatures ...OK. PM backup saved to "C:\mobileEx\3.5\data\backup\35521603853354_201301 21174614_308.1.PM" ERROR: BB5 SW Downgrade patch failed ! Battery voltage: 4788 mV Phone type: RM-469 (Nokia E52-1) Product code: 0583919 SW version: 091.004 LanguagePkg version: 091.004091.004.02.01091.004.C00.01 Waiting for USB device removal ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 2420021828660344C40C18B09B492D11957F73D9 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID: 3E273BF637BE26FA Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 190B292B FUR: Adding Asic CMT as client OK. Updating CMT NPC ...OK Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 190B292B Waiting for USB device removal ... Device connected: nmwcdc\Nokia E52 USB Phonet, PORT_ID: 1A8D8D90 Verifying communication to device OK. Phone type: RM-469 (Nokia E52-1) SW version: V ICPR82_11w16.3.11 29-03-12 RM-469 (c) Nokia ApeCoreSw: 091.004 Imei plain: 35521603853354-6 Product code: 0583919 Battery voltage: 4788 mV, current: 3083 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
01-21-2013, 21:10 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. You only having NPC Backup, If you're having Full RPL Backup or PM saved, can write it will solve it. BR, ZUBER |
