07-24-2011, 05:53 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: R A J A S T H A N
Member: 333796 Status: Offline Sonork: 100.1587155 Thanks Meter: 83 | e52 dead by usb fash then flash by usb result dead ( vibrate only ) log here MXKEY Serial: [FT SCR2000 0] - C0802438 Driver: NMWCD, ver: 7.1.32.70 Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.11875(12-07-2011) Processing MCU file: rm469_071.004_prd.core.fpsx [BB5,XSR 1.6] size: 104.62 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2941B531 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] CMT EM0 ID: 00000C34 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 1990001788600344AC24E9D436D060E4F814F6A7 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID: 3E273BF637BE26FA Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2941B531 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35521603120184_CE RT.rpl). CMT PAPUBKEYS HASH: 85F252E351E225CAFC4DFBC8041EABD2823E3500 Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 173.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0B13FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 85F252E3 [RAP Certificate 147 v.1] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 20.140 s Processing PPM file: rm469_071.004_14.01_APAC1_prd.rofs2.fpsx [BB5,XSR 1.6] size: 41.19 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 41.75 MB CMT FLASH,MuxOneNAND area [07340000-09CFFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 7.812 s Processing PPM file: rm469_071.004_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 8.43 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 20.25 MB CMT FLASH,MuxOneNAND area [09D00000-0B13FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 1.609 s Processing CNT file: RM469_APE_ONLY_ENO_09wk23v0.091.fpsx [BB5,XSR 1.6] size: 2.54 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 4 MB CMT FLASH,MuxOneNAND area [004E0000-008DFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.500 s Processing CNT file: rm469_071.004_U005.000_prd.uda.fpsx [BB5,XSR 1.6] size: 8.03 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 65.25 MB CMT FLASH,MuxOneNAND area [0B140000-0F27FFFF] Flash programming ... Programming completed in 1.563 s Total time for flashing process(boot+erase+write) was 43.485 s Waiting for device boot up ... Phone not found, retrying ... Phone not responding ! what will i do |
07-24-2011, 08:47 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | reinstall all E52 and manual delete and download here and insall and repeat procedure Blue-Nokia.com by Obnoxy E52 (RM-469) Major 054.003 v10 (MEA) E52 (RM-469) Major 054.003 v10 (EURO) dont forget MMC FILE,FLASH VIA MX KEY ----------------------------------------------------------------------------------- Some have an additional problem. format with *+3+yes-green key not work HEAT rap IC .. |
The Following User Says Thank You to sajohaker For This Useful Post: |
I have 5.28 unlocker by cable. | GreEn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 15 | 07-13-2000 21:57 |
5.28 working solution by eeprom 24x16 | SLO/EU | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-22-2000 15:55 |
nokia nse-spv8 by zulea | rothmanns | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-12-2000 07:52 |
have nokia lock 2 solution by cable | oskarcore | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:49 |
