11-03-2009, 02:38 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: CAIRO Age: 37
Member: 237684 Status: Offline Thanks Meter: 66 | E52 flash Error and final version from flash file when i search i found the same prop but the solution is uninstall the main setup and remove the folder i try it but :s by USB and F-bus as u know i use agood f-bus GPG cable i think it need good loaders or mx-key cannot flash this phone but howwwwwwwwww plz help |
11-04-2009, 16:42 | #4 (permalink) |
Member: 237684 Status: Offline Thanks Meter: 66 | 1-how can i check rx-2 line 2- all people can`t flash this model by mx key its need anew loader where i can download it 3-and whats is the direct i put it in coz it RAPU- YAMA E52,6260,6710s so plz help and dont tell me about what i dont know THX |
11-09-2009, 23:33 | #7 (permalink) |
Member: 237684 Status: Offline Thanks Meter: 66 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.10913, Date: 05-11-2009 Invalid File Header Flashing terminated with error(s) in 0.312 s RX Buffer: thxxxxxxxxxxxxxxxxxxxx |
11-10-2009, 06:27 | #8 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 493553 Status: Offline Thanks Meter: 24 | Mxkey not support flashing E52 : Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.10913, Date: 05-11-2009 Processing file: rm469_021.013_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 95.85 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM1 ID: 00000C34 EM2 ID: 00000C30 PUBLIC ID: 1E700011005F03443550AB12750161280E23A7D5 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP ExtBUSC: 0003 3FE0 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS is blank/erased. Error sending hash 0xED ! Flashing terminated with error(s) in 17.859 s RX Buffer: 0400000000B172 |
11-10-2009, 11:26 | #9 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Factory Unlocked :D Age: 44
Member: 91995 Status: Offline Thanks Meter: 76 | hi, i'm getting same error Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.10913, Date: 05-11-2009 Processing file: rm469_021.013_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 95.85 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Bootstrap failed! Flashing terminated with error(s) in 51.906 s RX Buffer: |
11-17-2009, 09:42 | #11 (permalink) |
Crazy Poster Join Date: Apr 2009
Member: 1015550 Status: Offline Thanks Meter: 5 | Yes use latest version it is working 100% and here is proof Model: E52 using usb Library version: 1.0.0.10913, Date: 05-11-2009 Processing file: rm469_021.013_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 95.85 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Phone must be switched off, Put USB cable to the phone. Connect a CHARGER or Press phone's POWER button and hold for a second please ! [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: F5223DA RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM1 ID: 00000C34 RAP EM2 ID: 00000C30 RAP PUBLIC ID: 17D000027A6003449253D3281F3CF1028099EF70 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.38.1 revision: 2.1 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Secondary boot loaded FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: ONENAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.38.1 revision: 2.1 size: 0x7EE22 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] PASUBTOC sent. [ADL] ALG sent. [ADL] Update Server code loaded [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: F5223DA [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: 85F252E351E225CAFC4DFBC8041EABD2823E3500 Total erase size: 64.00 KB Flash programming ... Valid PAPUB key found. CMT PAPUBKEYS: 85F252E351E225CAFC4DFBC8041EABD2823E3500 (RAP Certificate 147 v.1) written. Programming completed in 1 min 52.750 s Processing file: rm469_021.013_07.01_Balkans_prd.rofs2.fpsx as PPM [BB5,XSR 1.6] size: 33.13 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Total erase size: 41.75 MB CMT ONENAND area [07340000-09CFFFFF] erased in 0.187 s Flash programming ... Programming completed in 38.813 s Processing file: rm469_021.013_C00.01_DEFAULT_prd.rofs3.fpsx as PPM [BB5,XSR 1.6] size: 7.55 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Total erase size: 20.25 MB CMT ONENAND area [09D00000-0B13FFFF] erased in 0.094 s Flash programming ... Programming completed in 8.859 s Processing file: rm469_021.013_U001.000_prd.uda.fpsx as CNT [BB5,XSR 1.6] size: 670.27 KB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Total erase size: 65.25 MB CMT ONENAND area [0B140000-0F27FFFF] erased in 0.297 s Flash programming ... Programming completed in 1.234 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia E52 USB Generic, ID: 3C5186F [ADL] Verifying communication to device OK. Flashing completed in 4 min 18.078 s |
11-17-2009, 10:52 | #13 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | For these new models Phoneix is the best and safest at the moment,use dead USB and get your phone flashed in 3 minutes.Hope other tools update safe loaders soon, |
The Following User Says Thank You to meisam For This Useful Post: |
e52 flashing error! | jijeesh | HWK | 7 | 04-14-2010 23:08 |
E52 flashing error! | jijeesh | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-26-2010 06:20 |
e52 flashing error how to fix it?????????????????? | nofear197979 | HWK | 2 | 10-30-2009 12:07 |
E52 flashing error | dharmdev | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 10-12-2009 15:57 |
