Old 07-23-2011, 16:37   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::e52 gives this error::..(ANSWERED)
MXKEY Serial: [FT SCR2000 0] - C0805720
Using device: AdvanceBox Turbo Flasher
Driver: FTDIBUS, ver: 2.6.0.0 , NTMP ver: 2.6.2.0
Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011)
Processing MCU file: rm469_051.018_prd.core.fpsx
[BB5,XSR 1.6] size: 100.28 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
CMT Data :
SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1]
EM0 ID: 00001040
EM1 ID: 00001030
PUBLIC ID: 25E0010ADA6C03444B885D9C7DAE51A68A824EDA
ASIC MODE ID: 00
ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
ROM ID: 3E273BF637BE26FA
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.10.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
TransmissionMode: DDR&TX2
FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: MuxOneNAND,CMT
ALG [35]: XSR 1.6
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.10.0 revision: 3.0 size: 0xC621C
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 173.06 MB
CMT MuxOneNAND area [00020000-0003FFFF]
CMT MuxOneNAND area [00060000-004DFFFF]
CMT MuxOneNAND area [008E0000-0B13FFFF]
Error while erasing, Result: FF000000000000 , 0
Task failed at (08000008)!!!
Last RX buffer: FF
Old 07-23-2011, 18:27   #2 (permalink)
foufou34's Avatar
Member: 695274
Thanks Meter: 814
try with usb cable and post result...................................
Old 07-23-2011, 18:47   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::e5 problem need help::..
got one e5 in flash ic problem
so i carefully remove faulty flash chip
and put new one
but set is on vibrate
here is bus chk logs:
CMT Data :
SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1]
EM0 ID: 00000C35
EM1 ID: 00000C30
PUBLIC ID: 25500203B4A403441C8063DD608967C739A2D857
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 00EC 0050 - 0000 0031 [Samsung ] type: MuxOneNAND,CMT
ALG [35]: XSR 1.6
CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C
Original Imei: 35202304992699
Original Product code: 0595210
Bluetooth ID: 181456FE61BB
SIMLOCK PA identifier:
[0] PA_SL3
Phone not responding !
Old 07-23-2011, 18:48   #4 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
wat should i do
on scan it show phone not responding?
please help?
Old 07-23-2011, 18:52   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
here is rpl and pm
please chk is that alright or not?
Old 07-23-2011, 21:49   #6 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 283
Originally Posted by HUM View Post
here is rpl and pm
your pm is 04.06.2011
Your problem is a possible hardware.
check the hardware section
Old 07-23-2011, 21:55   #7 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 283
If you set up properly flash ic
first try this ..download latest firmware and flash dead usb..
Old 07-23-2011, 23:56   #8 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
wat is this sir..........................?
Old 07-23-2011, 23:57   #9 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
set not detected on usb..........................
Old 07-24-2011, 09:28   #10 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 283
bro pm is different date SL certificate..
performed one month before backup pm..
prob again backup pm...
Now you can execute backup pm.
changed ic..option is not set.
Try it on different cable,,, sometimes they are not good.
or a hardware problem
Old 07-24-2011, 21:44   #11 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
any suggestion from mxkey team .........................?
Old 07-24-2011, 21:45   #12 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
help needed from mxkey team.......................?
Old 07-25-2011, 13:48   #13 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
before proceeding, please download and install 3.5rev.1.2 and do synchronize files.
let's talk after you work with newer version.
New to all this (about 1 hour) :) Mark UK Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 10-01-2010 09:01
READ this IGOR_M!!!!!!!!!!!!! nightxyz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 11-04-2000 04:49
Has someome tested this software Nokia New Series Tool? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 09-20-2000 16:39
6110 unlocked but wont give reception KingOfKingston Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 04-10-2000 22:15
Don't trade with MC, I can Give you for FREE don Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 13 02-04-2000 22:09
Page generated in 0.26424 seconds with 10 queries
